trxrider Posted February 28, 2012 Report Posted February 28, 2012 Hello! I am new to this forum my first post, i have 2 CVX 15s on a boss 3800 watt amp and want to try building a ported box for them theyll be in the back of an avalanche so space shouldnt be an issue these are the chamber specifications for a ported box from the subs manual- box volume- 5 cubic feet port opening size- 3x15.5 port length- 22 power handling RMS- 900 (now ill have more then 900 watts so should the box be bigger) I was going to have them in seperate chambers but the same box can someone give me the detailed dimensions of the box i should build? ( easy to understand ive never built a box) should i use fiberglass or wood? should the subs be facing forward toward the cab or back towards the tailgate?
Joe X Posted February 28, 2012 Report Posted February 28, 2012 What is the exact model of your vehicle? what's the model of the boss amp?
trxrider Posted February 29, 2012 Author Report Posted February 29, 2012 2002 avalanche z71 i have the midgate out of the truck so the bed is open to the cab, the boss amp is a CE3800 monoblock D
Guest Posted February 29, 2012 Report Posted February 29, 2012 that amp will do 1200w on a good day. so your subs will see ~600 each, if that.
