10ga direct leads should get in the speaker outputs of that amp no problem. Looking at the pics of it online it looks like its 8ga outputs like my amps have. The power connections will be close for how they are right next to eachother. Usually amps that have the remote wire between the positive and negative have ample room for using a reducer. In your case id say just go out and buy a little distro block that goes from 1/0 to 4ga (they are out there so dont say they are not, i believe rockford has one that is very small but its not fused) and get like 6 feet of 4ga wire (3 for positive and 3 for negative) and then use the 4ga to go from the distro block to the amps + terminal and then from the amps ground to the chassis ground.
The only thing im not sure is your direct leads. If you have a big box the direct leads may not exit the box allowing you to connect it to the amp. Im not sure on the length of them but if they are long enough for you to just connect without making a connection on the box itself then just take the direct leads and unscrew the terminal on the amp and shove that wire in there and crank it down. It will fit for sure. 10ga is pretty common for subs now so only cheap crappy amps will not have a opening big enough for that.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
i know distro blocks exist ive had them in previous installs. and u got to use butt connectors for direct leads to had wire to it. and im probably gonna get the soundstream rubicon 1600d. my subs are only 350 rms each and i got 4 of em
Edited by 99blazer
08 Ford F150
