all the spaces around the wall close them
keep all the air going forward
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Ohhh okay!! Thanks!! i was planning on doing that when i get my polk 6x9 in. Since i took out the rear deck i planned on mounting them on the side of the box .
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
you should see a huge difference in the lows after you do that.
and make sure it is really sealed. dont be afraid of foam
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
if i took my wall to the b pillar then i wouldnt be able to put my seat back enough. thats why i didnt take it all the way up. So would i have to fiberglass it or something?
I have no idea how to go about sealing it. i have spray foam but not very much.
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
you gotta make some fun curves to match the contour as close as possible. then you can either foam it or if you dont want to fuxor your window use some gorilla tape.
itll still mess with your window but less than foam
or you can cover the window with something and then foam. like aluminum foil. if you have dark enough tint you wont see it
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
okay fursure!! i have the day off tommarow so maybe i can get those 'Fun curves" cut out and mounted
Do you really think it will made that big a difference in the lows im putting out?
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
