Review my setup ( seems it could be louder)
maybe he is chocking the 4 12" and does not have enough port? as well as electrical low voltage will hurt all your equipment period i have never heard anything bad about pioneer headunits but idk... thats just my experience i say box and electrical.
Get some pictures up. Take a picture of every ground you have in place. We'll start at the grounds and then go from there. The MM4000.1 isn't a bad amp. It is hifonics based. Switching to the BRZ 2400, might only give you a few hundred more watts, almost inaudible. If you want to see a difference, in the same box, it is time to start looking at those '3500' models. Crescendo, Audioque, Sundown, DC, etc... Gonna cost you more out of the gate, including the electrical but if you don't notice a difference, I'd be real surprised. Ideally, your taget to getting louder should be doubling the power. Say you're putting out 800 watts now, and 1100 (Clamped) when we're done helping you out. Your next target should be 2200 watts (Clamped)
On a side note, with the voltage where you're sitting, the amp could potentially perform quite a bit better, run cooler, etc with a little work to your electrical system.
Your car probably doesn't have seats that fold down does it?
This little thing right herehttp://www.sonicelectronix.com/item_25489_Crunch-P1-1000.2.html
http://www.sonicelectronix.com/item_26140_Rockford-Fosgate-T500-1bdCP-2010-Model.html
Get some pictures up. Take a picture of every ground you have in place. We'll start at the grounds and then go from there. The MM4000.1 isn't a bad amp. It is hifonics based. Switching to the BRZ 2400, might only give you a few hundred more watts, almost inaudible. If you want to see a difference, in the same box, it is time to start looking at those '3500' models. Crescendo, Audioque, Sundown, DC, etc... Gonna cost you more out of the gate, including the electrical but if you don't notice a difference, I'd be real surprised. Ideally, your taget to getting louder should be doubling the power. Say you're putting out 800 watts now, and 1100 (Clamped) when we're done helping you out. Your next target should be 2200 watts (Clamped) On a side note, with the voltage where you're sitting, the amp could potentially perform quite a bit better, run cooler, etc with a little work to your electrical system. Your car probably doesn't have seats that fold down does it?
Seats do not fold your right the amp is going to get sold if i can make over 1500 watts with it. I am skipping the electrical because the amp .I would like to get electrical upgrades yet im feeling like even with the upgrades it will not get much louder with the same amp.I can wire my subs to a higher ohm load swap to a smaller amp/more effecient ,then my electrical would be just fine ,either way i see no way it would get louder.
SuperBass
check out⊂ http://www.youtube.com/Bassknots
129.3 meca 136.8 db drag (60 hz peak)
http://bassknotsstereo.blogspot.com/
comment/subscribe and stay tuned ,working on 150 db http://www.stevemead...r/page__st__380
where in the bay are you? Maybe we can meet up and I can help you
XS Power D5100, 2 D2700s, & 2 D975s
MechMan 220a Alt
DC 5K
Kicker 650.4
2 12 Ascendant Audio Mayhem's
Pioneer DEH-P7200HD
Rockford Fosgate 3sity.1
Build log: https://www.stevemeadedesigns.com/board/topic/166792-88-nissan-maxima-trunk-build/#entry2430899
https://www.stevemeadedesigns.com/board/topic/191439-lexus-is300-fi-crescendo-shca-rf-pics/
HO alternator, couple big batteries, some real subs and you'll be doing 150's in no time
Some real subs like ??
SuperBass
  • Who's Online   1 Member, 0 Anonymous, 1183 Guests (See full list)
