Ok i had prev. installed a alpine 4 chgannel amp and then got a 15 inch rockford subs and kenwood amp. I installed everything the same as i did for the alpine but didnt run a distribution blockl due to getting a capacitor this weekend that has one built in, I ran the power wires together to the trunk and yesterday during a rainy day my subs started cutting in and out. after some trouble shooting i found this.
http://i44.photobucket.com/albums/f2/Necorum/Picture112.jpg
what is the cause of this?
Ps i used different brands of wires. rockford fosgate for the alpine and some offbrand for the kenwood. Im guessinf cheap wire.
Edited by Necorum
picture looks like a piece that you cut off with a burnt end on it.
You would be correct . The wire i cut it off (its too cold to sit and take pics outside) and one end was charred the red that connected to my battery
I would have to say too much current draw for that wire. Is it cheap wire or smaller than what you had?
cheap wire ... should i change the cheap wire onto the smaller alpine 4 channel amp and the rockford wire to the bigger amp (sub amp) til i can get a better wire?
yep, give that a try
Pretty sure the alpine mrp-240 4 channel 50x4 takes less to power than the kenwood kac-7203 250 rms x 2 @ 2 ohms amp powering the 15's.
Oh the gain is up rather high due to my head unit should i tuirn that down a bit? (think i read something somewhere online about doing this might be wrong)
Edited by Necorum
  • Who's Online   1 Member, 0 Anonymous, 5070 Guests (See full list)
