ehckz Posted March 1, 2012 Report Share Posted March 1, 2012 I ordered a vvx12 too hold me over for 2-3 weeks until my lvl4s get here and I have time away from college to put them in. So I need a quick box design for a vvx12, its going to be seeing probably 1200-1500 rms so I know the box will need to be a little smaller than specs but I'm not sure. So im in need of a quick cut sheet for a decent design just to have some decent temp bass, tuned to like 34ish or w/e you want to make it. so dbl rms, ported, around 34hz, dimension limits for this would be like 15h x 24w x 18d <--those r maximums for this box so i dont expect it to be that big lol. thanks in advance (ill put a vid up showing your design in action this weekend ) Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60 Link to comment Share on other sites More sharing options...
Joe X Posted March 1, 2012 Report Share Posted March 1, 2012 1500W? Link to comment Share on other sites More sharing options...
ehckz Posted March 1, 2012 Author Report Share Posted March 1, 2012 1500W? I know its overkill Ill just keep gain down...not going to buy a temp amp so it will have to do Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60 Link to comment Share on other sites More sharing options...
smceachran Posted March 1, 2012 Report Share Posted March 1, 2012 based on ur dimension limits it is a pain in the ass to make a good box tuned to 34hz. for me it is anyways. lol Link to comment Share on other sites More sharing options...
Joe X Posted March 1, 2012 Report Share Posted March 1, 2012 So here is a suggestion: Enclosure Specifications: Fb = 34.033 Hz Vb = 1.5 ft^3 Subwoofer Mounting = Flush Mounted External Height = 14 in External Width = 20.5 in External Depth = 18 in Port Width = 1 3/4 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 18 x 12 1/2 Front Internal = 16 1/2 x 12 1/2 Back = 20 1/2 x 12 1/2 Left & Right Sides: Side 1 = 16 1/2 x 12 1/2 Side 2 = 17 1/4 x 12 1/2 Top & Bottom = 20 1/2 x 18 L Port Internal Assembly Parts: Front to Back = 14 3/4 x 12 1/2 Extension = 11 1/4 x 12 1/2 Extension = 11 1/4 x 12 1/2 Link to comment Share on other sites More sharing options...
smceachran Posted March 1, 2012 Report Share Posted March 1, 2012 joe i like ur designs btw just thought id let you know. lol Link to comment Share on other sites More sharing options...
ehckz Posted March 1, 2012 Author Report Share Posted March 1, 2012 So here is a suggestion: Enclosure Specifications: Fb = 34.033 Hz Vb = 1.5 ft^3 Subwoofer Mounting = Flush Mounted External Height = 14 in External Width = 20.5 in External Depth = 18 in Port Width = 1 3/4 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 18 x 12 1/2 Front Internal = 16 1/2 x 12 1/2 Back = 20 1/2 x 12 1/2 Left & Right Sides: Side 1 = 16 1/2 x 12 1/2 Side 2 = 17 1/4 x 12 1/2 Top & Bottom = 20 1/2 x 18 L Port Internal Assembly Parts: Front to Back = 14 3/4 x 12 1/2 Extension = 11 1/4 x 12 1/2 Extension = 11 1/4 x 12 1/2 I will give that design a shot. Going to get the wood tonight after class, should have it in on saturday. Hopefully the skar can take some short term abuse. Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60 Link to comment Share on other sites More sharing options...
DaveBoutilier Posted March 2, 2012 Report Share Posted March 2, 2012 Wow that's awesome you couldn't whip up something for 4 15 inch w0v2s could you? I was thinking 40" wide 38" high 16.5" deep, tuned to 35 hz port would be 30" high 6" wide 25" long or whatever you think is best! It going to be 2000 watts rms in an s10. Thanks and let me know if You need more info. current score-156.6 sealed on the dash 4 ZV3 15s 1 AB 1100.1 Link to comment Share on other sites More sharing options...
Joe X Posted March 2, 2012 Report Share Posted March 2, 2012 joe i like ur designs btw just thought id let you know. lol Thanks smceachran! Link to comment Share on other sites More sharing options...
