Can I get a quick box design (cut sheet)
ehckz
I ordered a vvx12 too hold me over for 2-3 weeks until my lvl4s get here and I have time away from college to put them in.
So I need a quick box design for a vvx12, its going to be seeing probably 1200-1500 rms so I know the box will need to be a little smaller than specs but I'm not sure. So im in need of a quick cut sheet for a decent design just to have some decent temp bass, tuned to like 34ish or w/e you want to make it.
so dbl rms, ported, around 34hz, dimension limits for this would be like 15h x 24w x 18d <--those r maximums for this box so i dont expect it to be that big lol.
thanks in advance (ill put a vid up showing your design in action this weekend :good: )
Build In Progress for Slamology 2013
3 m1xl 18s walled in a gti
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
1500W?
I know its overkill Ill just keep gain down...not going to buy a temp amp so it will have to do
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
So here is a suggestion:
Enclosure Specifications:
Fb = 34.033 Hz
Vb = 1.5 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 14 in
External Width = 20.5 in
External Depth = 18 in
Port Width = 1 3/4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 18 x 12 1/2
Front Internal = 16 1/2 x 12 1/2
Back = 20 1/2 x 12 1/2
Left & Right Sides:
Side 1 = 16 1/2 x 12 1/2
Side 2 = 17 1/4 x 12 1/2
Top & Bottom = 20 1/2 x 18
L Port Internal Assembly Parts:
Front to Back = 14 3/4 x 12 1/2
Extension = 11 1/4 x 12 1/2
Fb = 34.033 Hz
Vb = 1.5 ft^3
Cut List:
Front = 18 x 12 1/2
Left & Right Sides:
I will give that design a shot. Going to get the wood tonight after class, should have it in on saturday. Hopefully the skar can take some short term abuse.
1 5k
4 batts
audio technix 1/0
8 cheap r/f 6.5s
mb quart 4.60
Wow that's awesome you couldn't whip up something for 4 15 inch w0v2s could you? I was thinking 40" wide 38" high 16.5" deep, tuned to 35 hz port would be 30" high 6" wide 25" long or whatever you think is best! It going to be 2000 watts rms in an s10. Thanks and let me know if You need more info.
current score-156.6 sealed on the dash
4 ZV3 15s
1 AB 1100.1
  • Who's Online   0 Members, 0 Anonymous, 1562 Guests (See full list)
