box size for a 2001 camry
MD7786
I was wondering if n e one knew a great box I could build for my camry. The one i have isnt tuned and I think mine could be louder. The one i have is 4cuft and barley ffits in my trunk for one 1300 rms psi 15
So post your maximum dims, and the external dims of the box (and the port) to see what could be wrong with the box.
31 inches w, 17.5 inches h, and 23 l. The 23 has to stay the same cause that's the max fit with the trunk lid. My Max are 23 l, 36 w, and and maybe 18 h.
Do yo have Psi Plataform 2 15" sub?
Ok a couple of more questions, the dims of the port (Width, height, length) of your current box and what amp, electrical system do you have in place.
I think the port is 6 inches across, all the way back with 2 inch from back, and its all the way up the side. I have a stock alt, 80 amp, jl 1000/1 amp, with 2 yellow tops one in back ,0 ggauged and about to do big 3. Does that make sense. Lol.
Your electrical is ok for that amp, go ahead and do the big 3 but bear in mind that the amp cannot provide the "1300W" to the sub, also the internal end of the port should be at least 6" from the sidewall, that mistake will tune lower the box and potentially make it loose some output, and also you need 6" of free airspace in front of the outer end of the port.
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
