YoungTitan Posted March 2, 2012 Report Share Posted March 2, 2012 Hey , I just ordered a HDC3 18 to put in my Titan. I plan on putting it on a hifonics bxi2600 untill I get a better amp. I took my back 40% seat out behind my divers side and it's about 30 inches from back to the back of my seat and about 18 inches from side of door to the center "hump" on the floor. Not real sure on what I should do. Should I go sub up port up ? Looking to tune to 35 hertz. Any idea ? Thanks in advance. Looking to get back built before it comes in. Quote Link to comment Share on other sites More sharing options...
fmedina Posted March 2, 2012 Report Share Posted March 2, 2012 i would say since its a truck and youre not walling it sub up port up or sub up port front to driver seat might both be good. send me a pm and ill be able to help out Quote Link to comment Share on other sites More sharing options...
Joe X Posted March 2, 2012 Report Share Posted March 2, 2012 Post your maximum dims, port up sub up can work if you have something like 19" D. Quote Link to comment Share on other sites More sharing options...
YoungTitan Posted March 2, 2012 Author Report Share Posted March 2, 2012 MAX MEASUREMENTS W 30 H 30 D 18 Quote Link to comment Share on other sites More sharing options...
Joe X Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) Well, this is preliminar, sub flush mounted to the front, slot port up on a side: Enclosure Specifications: Fb = 35.062 Hz Vb = 5.853 ft^3 Subwoofer Mounting = Flush Mounted External Height = 30 in External Width = 30 in External Depth = 18 in Port Width = 5 1/2 in Cut List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 30 x 30 Left & Right Sides = 15 3/4 x 28 1/2 Top & Bottom = 30 x 15 3/4 L Port Internal Assembly Parts: Front to Back = 21 1/4 x 15 3/4 Other options can be explored, like aero ports, some brancing is necessary mainly front to back, let me know any questions and if you would need a pic of the design. Edited March 2, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
Loslam Posted March 2, 2012 Report Share Posted March 2, 2012 (edited) Imo with the AQ woofer's, especially with the 18, you'll be happy with the lows output from 38 hz. Unless you really want low lows at 35 hz(would limit your cubes, they like 6ish each) That being said, here's a design with your max dimensions. edit: forgot to mention I took into account sub displacement and double baffled, if you did supports it would raise the tuning a tiny amount sub forward, port up And the specs Cheers! Edited March 2, 2012 by Loslam Quote 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/ Link to comment Share on other sites More sharing options...
YoungTitan Posted March 3, 2012 Author Report Share Posted March 3, 2012 I like those designs ! Now should I put the sub facing the door panel or the other way ? Thanks for y'alls replys ! Quote Link to comment Share on other sites More sharing options...
YoungTitan Posted March 3, 2012 Author Report Share Posted March 3, 2012 Also joe x , I'm liking that also. If you don't mind , sons pics would be fantastic. Quote Link to comment Share on other sites More sharing options...
dfoland93 Posted March 3, 2012 Report Share Posted March 3, 2012 Sub up port facing cabin Quote The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine Link to comment Share on other sites More sharing options...
YoungTitan Posted March 3, 2012 Author Report Share Posted March 3, 2012 Sub up port facing cabin I don't have the space to do that. Quote Link to comment Share on other sites More sharing options...
