ok now that i have tracked down my symmetry (although the more i look at the rf 360.2 the more like ) I can do 3 way active comps.
the original rcas are split one to the symmetry one to the 100.2 on a set of passive comps.
amps are
3 sundown 100.4's
2 sundown 3000d's
1 sundown 100.2
subs are 15 inch sundown nightshade's
mid-bass's , mids and tweets are undecided
can i use the 3sixty or should i stick with the symmetry i wanna you the 3sixty. but im not grasping the output wiring on the 3sixty.2 at all.
Edited by f3rr3t
that would be sick if it could...
megalo are you running 4 way active?
from what i think i understand it is pretty difficult to have 4 way set up and sound good...i dont know if this is true just what i thought i read somewhere
2005 Nissan Altima 2.5 S
HU: AVIC-D2
Fronts: ARC Audio KAR KS6006 Components
AA Poly Mids/ CDT CW-19 Tweets in kicks
Front Amp: Profile AP400x2
Rear Fill: None
Sub: DC LVL 4 (CF Dustcap) x2 (waiting for dustcaps)
AMP: RF t10001bd x2 (1400-1500 @ 1 ohm)
Wire: Welding Supply/Lighting Audio 1/0 Power/Ground
Zero Noise 2.0zn RCA (x2)
260 Amp Iraggi Alternator
Guest MegaloManiac
no you would need 2 360.2 to achieve what you are asking. the sub channel doesnt let you cross high at all. you can download the software from RF and you can see the options its capable of
what meglo said......in both posts :D And Assman too (i use 2)
it'd be nice to not have to use 2 3sixty's but its no big deal really. Id like to see a 3sixty.3 or 4 or whatever though.
Follow my Tweet (Twitter)
i asked rf tech support heres my question
"i need to hook up all 3 100.4s to the 360 for my 3 way active system. can it be done. heres a diagram"
there answer
Thanks for contacting us. Yes, that would indeed work. A couple quick notes.....You won't have fader control, including myself not many people care about that anyway. For the 3Sixty to work it needs to have at least a Left and Right connected to the Front inputs, the unit will automatically give you a summed output on the center and sub if no input is present.
what does this mean? "the unit will automatically give you a summed output on the center and sub if no input is present."
Guest MegaloManiac
if you download the software you can see for your self
3sixty.2 software download
yes you wont get a front rear fader anymore since you are doing a stereo 3-way setup
but there is only 2 sets of rca and + 1 sub(y-adaptor would be used) that can be used. front channels would be Highs and rear channels would be mids and sub channel is low. the center channel is rather useless since its limited range and it wont be stereo if you use a y-adaptor, understand?
so only 3way(tweet,mid, & sub) is possible not 4way due to the limited range in the last channel.
Edited by MegaloManiac
  • Who's Online   1 Member, 0 Anonymous, 1616 Guests (See full list)
