My outside dimensions at 38 wide, 15 tall, 18.75 deep.
I would like to tune the box in the low 30Hz range (29-33) but I have no idea how to figure in the port and tune it. I have always built sealed boxes or had someone else design the ported box for me and I built it to spec.
I listen to a lot of Dubstep and Rap/hip-hop. This is my daily driver as well. The subs will be powered by a HiFonics Brutus 2100.1D.
Thanks in advance for helping.
2004 Pontiac Vibe Build
Sony MEX-N5000BT
JBL P660C x 2
Sundown Audio Zv4 18
Crescendo BC2000D
Crescendo S800/4
Execution Audio 0 AWG Wire
Sky High Car Audio RCA's
Toolmaker Terminals
XS Power D1200
DC Power 240HP Alternator
Viper 5706
So here is a suggestion port/subs on the same face:
Enclosure Specifications:
Fb = 30.029 Hz
Vb = 3.346 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 15 in
External Width = 38 in
External Depth = 18.75 in
Port Width = 3 1/2 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 33 3/4 x 13 1/2
Front Internal = 32 1/4 x 13 1/2
Back = 38 x 13 1/2
Left & Right Sides:
Side 1 = 17 1/4 x 13 1/2
Side 2 = 18 x 13 1/2
Top & Bottom = 38 x 18 3/4
L Port Internal Assembly Parts:
Front to Back = 13 3/4 x 13 1/2
Extension = 16 x 13 1/2
Let me know any questions.
Thank you so much! That is exactly what I was looking for. As soon as it gets warmer... I will be building this. I will probably 45 all of the corners though. :)
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Nice, just take care with the port corner, the cross sectional area of the port must stay at least 3.5" wide, if the 45 is too big that will alter the tuning.
tooks good
Duel Sa-8 V.2 D2 Sub Enclosure
2001 Pontiac Grand am
  • Head Unit - OEM
  • Processor - RF 3sixty.2
  • Subs - RE Audio SXX12D4
  • Amplifier - Kicker ZX1000.1
  • Mids & Highs- Rockford Fosgate Power T2652-S
  • Rockford Fosgate Power T1693
  • Mids & Highs Amp - Rockford Fosgate Power T400-4
  • Wiring - 1/0 AWG, 4 AWG, 8 AWG
  • Alternator - Stock
  • Batteries - non ext
  • Box- Absolute PSEB12BK
Good to know. I will leave it like that then. I am going to flush mount the subs though.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
Will this design have issues with the sub on the right unloading further back than on the port wall? Will I see any fault in this design?
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
NO, anyways, if you are going to be worried about this you can go with a dual chamber design, either shared port or separate ports, those designs though take up more internal airspace and need more port parts.
Ok thanks, I am going to just go ahead with these plans. I am just waiting for it to get a little warmer out here in Michigan and I can start building.
Sony MEX-N5000BT
JBL P660C x 2
Crescendo BC2000D
Crescendo S800/4
Toolmaker Terminals
XS Power D1200
Viper 5706
