New MTX Thunder dual 2 ohm 12s and alternator upgrade LOUD
you would think that he would know (i mean being an electrition) when u add 2 12volt sorces together in parallel it stays at 12 volts it just makes the amps go up. the only way to get more voltage is 14 or 16 volt batterys and turning the aftermarket voltage controler up. or hooking them up in series and blowing everything
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
series batteries add up..in a series circuit current stays the same..they are also known voltage dividers....
parallel circuits voltage is the same...known as current dividers...
The alternator and battery can read 17 volts at the most my cars meter goes to 18
http://m.youtube.com...h?v=Ekiqso9hWFQ volts
yeah the ink printed on paper can show 9 to 18v with a needle pointing to current voltage, but that doesn't mean that your shit will produce 17-18v. only way it will do that with absolutely no modifications is if your voltage regulator goes bad.
edit: video doesn't even work
just like a 98 chevy pickup speedo says 120mph but it will shut down at 98mph
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
Oh here you go
The movement dosnt show well on my pink camera apparently.
Haha right.. its never been over 14 volts, some guy at batteries plus said it should measure 17 volts what a dumb ass, thats why you cant listen to what everyone tells you.
Im an electrician yall just get your info online
Does that question say. The meter used to measure electrical flow in a circuit? I haven't seen a question that easy since the first day pop quiz of my first EET course.
This thread is full of slow.lol
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
2008 Chevrolet ColoradoPioneer DEH-X9500BHSSundown SAX1200dFi Q12 loaded
Boston Acoustics GT-275 on: Pioneer TS-D1720cKinetic HC1200 XS power XP750
