The old set-up:
http://www.stevemead...-1996-xxx-cavy/
Decided to wall the Cavy early last year...just now finishing it up. I still need to finish the amp rack and the front of the wall. I also have to run new RCA cables...which will have to go under the car due to the wall being in the way. I did fire it up today and it sounds amazing! Can not wait to get this thing finished up!
2 - 18" Re SX with Fi soft parts
2 - AQ2200D sub amps
1 - AQ4x90 mid/high amp
Audiobahn 3 way set-up
Sony DSX-S310BTX Head Unit
The wall is 12.75 ft^3 tuned to 29hz..I think. This wall has so many different angles and the ports are all crazy...hard to determine the actual volume. I will put it on a TL this weekend to see where it ends up peaking in the car.
Wanted to save part of the box in the trunk for airspace in the wall.
2 - 18" re SX subs that I just reconed with Fi soft parts.
Each baffle is 1 1/4" mdf. 4 layers so it should be pretty strong.
Edited by KyleDykstra
Cool build. That wall looks solid as hell.
2005 Ford Focus zx4
AMT's and Planars
18" Infinite baffle
looks pretty interesting, keep it up man
2007 Chevy Silverado Ext Cab
kenwood excelon kdc-x995
4-jl audio tr650-cxi
1-single probox 10" upfire vented enclosure
JL audio 500/1 v1
JL audio jx 360/2
JL audio signal wires
Memphis 4 gauge
Kicker 2 gauge
LA 50 farad capacitor
24" U2 black rims 305/35/24
Oh noessss not another Grimey member :P:D
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
Man i wish you had taken more photos of your false floor there under the wall haha
shits looking good... you dont get port noise with all them ports do ya?
R.I.P!
(Nov-29-2009)
92 explorer
current build
beautiful work sir. keep it up.
its always good to see other cavi builds
Are the SXs the older models?
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
  • Who's Online   0 Members, 0 Anonymous, 503 Guests (See full list)
