KyleDykstra Posted March 8, 2012 Report Share Posted March 8, 2012 (edited) The old set-up: http://www.stevemead...-1996-xxx-cavy/ Decided to wall the Cavy early last year...just now finishing it up. I still need to finish the amp rack and the front of the wall. I also have to run new RCA cables...which will have to go under the car due to the wall being in the way. I did fire it up today and it sounds amazing! Can not wait to get this thing finished up! 2 - 18" Re SX with Fi soft parts 2 - AQ2200D sub amps 1 - AQ4x90 mid/high amp Audiobahn 3 way set-up Sony DSX-S310BTX Head Unit The wall is 12.75 ft^3 tuned to 29hz..I think. This wall has so many different angles and the ports are all crazy...hard to determine the actual volume. I will put it on a TL this weekend to see where it ends up peaking in the car. Wanted to save part of the box in the trunk for airspace in the wall. 2 - 18" re SX subs that I just reconed with Fi soft parts. Each baffle is 1 1/4" mdf. 4 layers so it should be pretty strong. Edited March 8, 2012 by KyleDykstra Quote Link to comment Share on other sites More sharing options...
KyleDykstra Posted March 8, 2012 Author Report Share Posted March 8, 2012 Quote Link to comment Share on other sites More sharing options...
KyleDykstra Posted March 8, 2012 Author Report Share Posted March 8, 2012 That is as far as I am at the moment. Will be ready to actually turn it up this weekend and see what it does. :-) Quote Link to comment Share on other sites More sharing options...
Kevin M Posted March 8, 2012 Report Share Posted March 8, 2012 Cool build. That wall looks solid as hell. Quote 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle Link to comment Share on other sites More sharing options...
auzzyb Posted March 8, 2012 Report Share Posted March 8, 2012 looks pretty interesting, keep it up man Quote 2007 Chevy Silverado Ext Cab kenwood excelon kdc-x995 4-jl audio tr650-cxi 1-single probox 10" upfire vented enclosure JL audio 500/1 v1 JL audio jx 360/2 JL audio signal wires Memphis 4 gauge Kicker 2 gauge LA 50 farad capacitor 24" U2 black rims 305/35/24 Link to comment Share on other sites More sharing options...
SoCaLBaMF Posted March 8, 2012 Report Share Posted March 8, 2012 Oh noessss not another Grimey member Quote 2004 Bagged Trailblazer (4)18" Sundown Nsv3s (4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4 (2)DC power SP 270s, (14)XS Power d3100s, (1)d6500 Link to comment Share on other sites More sharing options...
2loudisjustright Posted March 8, 2012 Report Share Posted March 8, 2012 Wall is looking good!! This should get pretty nasty!! I bet your little car is hating you for all that extra weight tho!! Quote 2000 zx2: Rebuild with 8 12s on a 10k underway!! MY BUILD LOG Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 8, 2012 Report Share Posted March 8, 2012 Man i wish you had taken more photos of your false floor there under the wall haha shits looking good... you dont get port noise with all them ports do ya? Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
DRCinc Posted March 8, 2012 Report Share Posted March 8, 2012 beautiful work sir. keep it up. its always good to see other cavi builds Quote Link to comment Share on other sites More sharing options...
dfoland93 Posted March 8, 2012 Report Share Posted March 8, 2012 Are the SXs the older models? Quote The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine Link to comment Share on other sites More sharing options...
