Stee-Z Posted March 12, 2012 Report Posted March 12, 2012 today i was just driving to work with my bass down low, then it kinda just starts playing about half power of what it usually does, then it would kick in sometimes and go to normal then half power again. Now it won't go back to normal, i checked RC's, all good. power and negitive are all hooked up good, no fuses blown, remote all good.....why is it doing this..? (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
TheNewbie Posted March 12, 2012 Report Posted March 12, 2012 Speaker wire is solid? Check out my build log: http://www.stevemead...60#entry1958353 Different folks have different strokes.
Stee-Z Posted March 12, 2012 Author Report Posted March 12, 2012 oh yeh, that to thats all good (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
Skullz Posted March 12, 2012 Report Posted March 12, 2012 Bad output from the H/U. Bad input on the amp. Possible short in the rca patch cords. Possible fuse not fully blown. Possible issue inside of the amp. Possible wiring issue inside the box. Possible coil problem. I would first start with a 1k tone set to repeat and measure your voltage output from the H/U rca's to make sure your getting proper voltage out, if your getting good signal out then check the rca'a connected to the H/U to make sure your getting the full voltage to the amp. Pull the fuse and replace it and see if that has changed anything just as a measure of possibilities the cross off the list. If everything else checks out and your still not getting full power you might want to pull the sub and check that nothing has come loose causing you to have one working coil, check the ohm load on all coils to make sure that there is nothing wrong with them or the wiring and if your still having issues then lastly you might want to swap amps and see if that finally changes anything. Comes down to a process of elimination. EDIT: use a 50hz test tone if it is the sub amp. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
bobobass Posted March 12, 2012 Report Posted March 12, 2012 I had the exact same issue about a week ago. It's probably you RCA's. They might check out ok, but their is probably a broken lead somewhere on the RCAs that is constantly breaking and making contact as it moves while you drive. A good way to test this is to have each connecter plugged into the amp separately and the side that's bad will cut in an out. 2000 Subaru outback 2.5l Head Unit: Pioneer deh 4300ub front stage: tbd subwoofer: Stock Fi Q 18" amp: Audio que 1200d
Stee-Z Posted March 13, 2012 Author Report Posted March 13, 2012 I had the exact same issue about a week ago. It's probably you RCA's. They might check out ok, but their is probably a broken lead somewhere on the RCAs that is constantly breaking and making contact as it moves while you drive. A good way to test this is to have each connecter plugged into the amp separately and the side that's bad will cut in an out. thats all i can really think of ... their 5$ rca's ha, and been using them for 6 months (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened
