I'm doing the research to rebuild my system. I've FINALLY found some subs that I like(DC LVL 3 15s). I'm still looking for an amp for these, for i'm on a tight budget. Does anyone have a box design for these subs. its going in a 98 Jeep Cherokee. max dims are 42" wide x 25" deep and the height doesn't matter. I'm interested in sub up/port back tuned to 32hz or lower.
Thanks in advance
Getting loud is only half the job;sounding good while doing it is where the glory is.1998 Jeep CherokeeHead Unit: Pioneer AVH-P6300BTFront Stage: Kenwood 6.5Rear Stage: kenwood 6.5Tweeters: SoundstreamMids/Highs amp: Hifonics Zeus 600.4Sub Amp: Hifonics BRZ2400Subs: 4 Skar VVX 10s(only running 2 now; still has all of them though)Batteries: Optima Red Top(under the hood)XS Power D1200(in the trunk)0 AWG Power Wire
Ok here is a suggestion on your specs, mfr suggested net volume per sub:
Enclosure Specifications:
Fb = 32.024 Hz
Vb = 6 ft^3
External Height = 19 in
External Width = 41 in
External Depth = 22 in
Port Width = 5 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 41 x 22
Left & Right Sides = 20 1/2 x 16 3/4
Front & Back = 41 x 16 3/4
T Port Internal Assembly Parts:
2 x Front to Back = 18 x 16 3/4
2 x Extension = 3 1/2 x 16 3/4
Assembly guide (generic dimensions):
Let me know any questions.
Edited by Joe X
Fb = 32.024 Hz
Vb = 6 ft^3
Port Width = 5 in
Cut Sheet List:
What would be the difference in sound between 3/4in MDF and 1" MDF? I kind of was looking at 1" since the guy that builds box uses 1" most of the time.
1" MDF is not necessary for these subs, but if it need to be I would have to redesign to a sligtly bigger box so that the spec stays the same.
Would 1" make a positive difference, if so would make one in 1" MDF. Thanks I really appreciate your patience.
Not enough to justify the increase in weight, I will add some extra bracing if you are concerned. Also some port optimizations.
I was just thinking about how much more weight it would add. especially on the saggy Jeep springs. Bracing would seem more plausible to me. What does port optimization mean not to sound dumb?
Edited by Papaslim
It will gain weight not only due to the thickness of the material but because the box needs to be bigger, I can add the bracing easily, port optimizations are put in place to reduce turbulent flow, check how a port turn can be optimized:
Adding bracing will be fine. it seems more sensible; especially if i'm only running 2,000w. Could you add the bracing and port optimization in for me?
Edited by Papaslim
Yes I will update the sketchup with the mods later by tonight, anyhow none of the specs above changes a bit.
  • Who's Online   0 Members, 0 Anonymous, 536 Guests (See full list)
