Posted (edited)
Just got my Rockford Fosgate T1s in today and i'm a complete noob since this is my first time installing mids and crossovers and what not. I took out my old stocks speakers and just have this wiring left in the door. What do i do cut it off and connect it to the crossover. I'm lost on this. Any help would be great.
Thanks
Edited by Diamond500
Are you going to be amping them or just running off hu power?
92 Honda Prelude SI H23a3
HU: Alpine CDA-105
Front Stage: DB Drive PT6.0 6.5"
Rear Stage: Junk pioneers (Not sure what im wanting to do in the trunk, waiting)
Speaker Amp: DB Drive A4 4200
Sub Amp: MB Quart DSC1500.1
Subs: 2 12" MB Quart Premiums
Box: Slot port tuned to ~34hz
Wiring: Kicker Ultraflex 0awg and Big 3
Alt: Stock (saving for a 200amp Excessive Amperage)
Batteries: Optima Yellow Top and Stinger SPV44
Extra Equipment:
Two Rockford Fosgate T2 12's (Recones in future)
Kicker ZX1000.1
Selling:
find which wire is pos. and neg, hook that to the cross over, then from the cross over to the tweet, and crossover to the mid, and yes you cut the connecter off
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
No amp straight to the headunit.
Do i have to solider the wire to the speakers then?
Either that, or go down to radioshack and get spade connectors the crimp those onto the speaker wire
Posted (edited)
No you need to do wire connectors, i mean you can solder them but i would just use connectors
EDIT: ninjad
Edited by h23a3lude
HU: Alpine CDA-105
Extra Equipment:
Kicker ZX1000.1
Selling:
I have spade connectors put won't fit i might have to open them a bit more. Wouldn't that mean i have to put 2 wires in the connector the one coming out of the door then 1 from the crossover to the speaker.
Wires from the door going into the crossover
Wires coming out of the crossover with spade terminals on one end going to the tweeter
Wires coming out of the crossover with spade terminals on one end going to the midrange
You shouldn't have to be jamming multiple wires into 1 connector for this :good:
Unless I am misunderstanding you lol
