Joe X Posted March 14, 2012 Report Posted March 14, 2012 (edited) The baffle suggested is like the one in the pic (from a different design), goes all across the height and width if the box: The main problem with that baffle style is that you need to cut through it to make your port, Many people have reported bad results attempting to cut that. Anyhow I can provide a cut sheet list for that type of baffle if you want. Ported enclosures work best with port/sub on the same face, if the port has no breathing room in front of it then you aim it where there is, another case is when using aero ports, most times wont fit and mounting on a different face is the only alternative. You can also choose the side on which you want the port eitheer passenger or driver. Edited March 14, 2012 by Joe X Quote
Hifonics Posted March 14, 2012 Author Report Posted March 14, 2012 Agreed. I'll just use more bracing to reinforce it all. Joe, do you think it would be better to tune lower? I listen to a variety of music but 70% of the time it's rap with low bass. Also, would it make a difference if I took an inch off the width and added an inch to the hight? Just so that it's not at my max dimensions and gives a bit of breathing room to move it a bit Just wondering Quote 2010 F150 FX4-18" AA Mayhem-Crescendo BC3500d-Pioneer GM-D9500F 4-channel-2 Crescendo FT1 -2 Crescendo Neo Forte 6.5 -Pioneer AVH-P3300BT-6000K HID Headlights/Fog lights-All LED interior lighting-20% tint on front windows, 1% rear windows, 5% windshield strip-Big3 (XSFlex 0ga) -DC Power 270XP -Group 65 NorthStar AGM battery Coming soon/plans: -Build log-Blacked out mirror reflectors-Tinted tails/3rd brake light
412 CVX Posted March 14, 2012 Report Posted March 14, 2012 like I did in this box. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
412 CVX Posted March 14, 2012 Report Posted March 14, 2012 (edited) Stop pulling stuff out of your ass, Joe. First off, as long as you cut out the port right and sand it if needed, there will be NO problems doing the port like that. Second, there are plenty of exceptions to that. in some trucks subs up, port to the side works best, in most SUV's subs up port back works best, and in some trunks, subs forward port firing to the side works best. Edited March 14, 2012 by 412 CVX Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Hifonics Posted March 14, 2012 Author Report Posted March 14, 2012 Stop pulling stuff out of your ass, Joe. First off, as long as you cut out the port right and sand it if needed, there will be NO problems doing the port like that. Second, there are plenty of exceptions to that. in some trucks subs up, port to the side works best, in most SUV's subs up port back works best, and in some trunks, subs forward port firing to the side works best. Can you show me what you would do for my truck? Tuned about 33-34hz. Max dimensions are on the first page Try not to max it though, give it a bit of wiggle room. so like take an inch off the max hight and max width. Depth is ok at max Quote 2010 F150 FX4-18" AA Mayhem-Crescendo BC3500d-Pioneer GM-D9500F 4-channel-2 Crescendo FT1 -2 Crescendo Neo Forte 6.5 -Pioneer AVH-P3300BT-6000K HID Headlights/Fog lights-All LED interior lighting-20% tint on front windows, 1% rear windows, 5% windshield strip-Big3 (XSFlex 0ga) -DC Power 270XP -Group 65 NorthStar AGM battery Coming soon/plans: -Build log-Blacked out mirror reflectors-Tinted tails/3rd brake light
412 CVX Posted March 14, 2012 Report Posted March 14, 2012 maybe later. i don't usually do charity work. but i'd probably do something similar to the box i posted earlier for the platform 3 PSI 18 Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Hifonics Posted March 14, 2012 Author Report Posted March 14, 2012 maybe later. i don't usually do charity work. but i'd probably do something similar to the box i posted earlier for the platform 3 PSI 18 No problem, I can do it myself I was just curious to see what you had in mind exactly. Quote 2010 F150 FX4-18" AA Mayhem-Crescendo BC3500d-Pioneer GM-D9500F 4-channel-2 Crescendo FT1 -2 Crescendo Neo Forte 6.5 -Pioneer AVH-P3300BT-6000K HID Headlights/Fog lights-All LED interior lighting-20% tint on front windows, 1% rear windows, 5% windshield strip-Big3 (XSFlex 0ga) -DC Power 270XP -Group 65 NorthStar AGM battery Coming soon/plans: -Build log-Blacked out mirror reflectors-Tinted tails/3rd brake light
Joe X Posted March 14, 2012 Report Posted March 14, 2012 (edited) Decide what advise you will take and I wil perform the mods, if you listen to rap type of music mainly, I would probably go to 33Hz. A port up / sub front can be done without a problem, it even has the advantage that you can go with an all across width/height baffle without cutting through it. Can you go a bit wider? Edited March 14, 2012 by Joe X Quote
412 CVX Posted March 14, 2012 Report Posted March 14, 2012 smh joe... smh Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
4Bent Posted March 14, 2012 Report Posted March 14, 2012 good luck man it really isnt difficult. the deeper you dig the harder it will be to get out. Quote BlowthroughSubs rebuild Amps 1-SAZ3500 1-T4004Coaxial 1Set Alpine Type-R Components 1 Set- kicker ks 5.21 Set- Kicker ks 6x8 Reciever Pioneer DEH-P7400HD2000 Ford F-150 EXT Cab Clarion EQ
