SmallTruk Posted March 13, 2012 Report Posted March 13, 2012 I'm running 4/0 welding cable front to rear and it occurred to me this weekend when i changed my alt that the 300a fuse I have at each end of the wire is just a fraction of what this 4/0 can actually handle. So my question is this....do you guy running large cables just use the biggest fuse you can find? A circuit breaker? Double up on 200a fuses? What would be the best solution? I found a few 350 ANL fuses for sale online but they're expensive and IMO <350 amps going through a piece of metal that thing seems unrealistic.
treylittlefield Posted March 13, 2012 Report Posted March 13, 2012 you use the fuse size of what your running or what your alt is, not what the wire can handle. thats how i would do it IMO
Cardboardcat15 Posted March 13, 2012 Report Posted March 13, 2012 you use the fuse size of what your running or what your alt is, not what the wire can handle. thats how i would do it IMO Fuse the wire, not the equipment. EDIT: Fusing the wire according to the alt/equipment pretty much defeats the purpose of a fuse. OP, here are some 400 amp fuses on ebay. ANL http://www.ebay.com/...cat=0&_from=R40 My Channel on YouTube. Check it out for cinematic-style Car Audio videos. https://www.youtube.com/channel/UCcSMhtT-rpopJbdybubDgnQ New 2014 Scion TC 4th Wall Build https://www.stevemeadedesigns.com/board/topic/217173-2014-tc-4th-order-build-3-fi-sp4-15s/
Craig28 Posted March 13, 2012 Report Posted March 13, 2012 https://vtewarehouse.com/content/electromech/fuse/html/anl/anlfuse.php 4 bucks a piece for fuses isn't bad. This places has a lot of electrical gear real cheap. Fuses, holders, bus bars, distribution blocks, etc. TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
SmallTruk Posted March 13, 2012 Author Report Posted March 13, 2012 you use the fuse size of what your running or what your alt is, not what the wire can handle. thats how i would do it IMO No. Maybe I wasn't clear but I'm talking about the wire that's running from the front to the rear battery bank. The wires for each amp are fused according to what they need. But the fuse that connects the alt to the rear batts should be what the wire can handle.
SmallTruk Posted March 13, 2012 Author Report Posted March 13, 2012 https://vtewarehouse.com/content/electromech/fuse/html/anl/anlfuse.php 4 bucks a piece for fuses isn't bad. This places has a lot of electrical gear real cheap. Fuses, holders, bus bars, distribution blocks, etc. That's not bad at all and those fuse holders they have look pretty damn cool. Apparently ANL fuses can go up to 500a so i guess Ill be fine with what I need. Thanks man
