hey guys recently i"ve been having this problem where my sub with cut out when i put my volume up high and then from then on it wont hit as hard its like theres not enough power going to the subs... it use to shake the hair on my head and now it barley does that :( ... help please
acutally it was did with a o scope then i checked it with the smd dd-1 ... grounded to body of the car yeah .. the black rca was a little loose and i checked that but its still making the problem
ill have to check bout the ground .. im also using a line out conveter but the metal on the rca on the brand that i have .. in the past the metal has came off the tip .
you should get some new rcas then if they're fucked up like that. Ground might be shitty if its on the body. Like rebel said, where is it on the body exactly? Is the metal sanded down etc?
how did you check the rcas? did you swap them out for a new pair?
and your ground isnt on some seatbelt bolt or some bull shit like that? where on the body is it grounded to? and it has the paint all sanded off i assume since you said its fine?
