XS Power
Box of the XP3000. The battery doesn't look damage with any cosmetics. I probably won't install the XP3000 until I get my DC Power 270A Alt unless you guys know it would be fine to run it now with the stock 90A Alt and with my current 1200W system.
A box within a box FTW! This one didn't have as much popcorn as the D2400 though :(
D2400 package on the right:
The D2400 had more popcorn:
XP3000 Voltage:
D2400 Voltage:
D2400 next to my old Yellow Top
Took out my yellowtop:
Stock Hold Down:
ONLY ONE PROBLEM!
I don't feel like getting a new bracket thing so I just need a longer bolt.
One question, is it fine to use the D2400 with 12.3V and just have the car charge it?
congrats i see no xp3000 on the website
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
Well, I've just hooked up the D2400 and it is only readin 14.2 to 14.3 with the engine on. My yellow top was reading 14.5V so what's going on?
After having my car idle for 15 minutes, the voltage went from 14.3V to 13.8V with the engine on. Should I drive around town first for the battery to charge up?
how about park your car, hook it up to a CHARGER like he is suggesting? you are SUPPOSED TO charge your batts from xs power before you run them.
charging does not mean turn your car and and let your alt charge it.. it means hook it up to a slow trickle charger.
please listen to what these guys are telling you to do!
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
you need to charge it.
I don't have a charger at this time. I'll have to dig into that one thread regarding how people should charge batteries overnight.
I was hoping that if I get a good alternator I wouldn't have to worry about charging the batteries :(
