hey guys I just got a DD 9515h and I was wondering if someone could help me with my box dimensions. I'm going to be running it off my M2a so about 2300 rms. My max dimensions for the box are:
D-30"
W-40"
H-16"
I'd like to double baffle the whole box to make sure it's not going to flex at all but do you guys think that I need to do that?
theres going to be a beautyboard in front of the box so the sub will sit flush and I plan on facing it into the cabin with the trunk sealed off
2007 Toyota Corolla
Sub:
DD M3c
DD 9515h D4 wired to 2ohm
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
XS 1/0 OFC (2 runs pos/neg)
Sky High machined set screw battery posts (all batts)
Score:
Never metered
help anyone?
Edited by 07corolla
2007 Toyota Corolla
Sub:
DD M3c
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
Score:
Never metered
Ok, here is a suggestion, within your dims and factoring in your power. Port/sub firing frontwards or backwards:
Enclosure Specifications:
Fb = 35 Hz
Vb = 3.897 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 16 in
External Width = 29.75 in
External Depth = 25 in
Port Width = 4 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 29 3/4 x 16
Left & Right Sides = 22 3/4 x 14 1/2
Top & Bottom = 29 3/4 x 22 3/4
L Port Internal Assembly Parts:
Front to Back = 18 1/4 x 14 1/2
Extension = 2 3/4 x 14 1/2
Assembly guide not showing bracing or port optimizations (generic dimensions!!):
Any changes you would like done? let me know.
Edited by Joe X
okay thanks I'll try that out
2007 Toyota Corolla
Sub:
DD M3c
Mids:
DD A2 (2)
DD VO 6.5 (4)
Power:
Js 180a alt
XS D1200
XS XP3000
XS XP975
XS 1/0 OFC (Big 3)
Score:
Never metered
  • 1 month later...
Well just make sure the dimensions the box fit your trunk and that is also on it's way in. If it doesn't fit in it's way in you may need to build inside.
  • Who's Online   1 Member, 0 Anonymous, 2837 Guests (See full list)
