IMO, 1.49 is pretty small for a 12 that is basically getting RMS. I suspect that f3 will not be very low, and I suspect you will be losing the output that a larger box typically garners
That's the recommended on the DC site.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Most DC Audio subs work in below average sized boxes, if fact the Pioneer TS-W3002 is recommended for 1.2 cubic feet ported and still gets real low.
Okay.. but yet I need a 12 inch woofer in there.. with 11.5 as a height how's that work? :o
The cutout diameter is 11" so it fits..tughtly, the outside diameter should be around 12.5" so it also fit.. you will have 1/4" clearance each side..very little, in fact I had to go for the all across Width/height baffle for this reason.
Damn, haha so the rubber will fit as well on the box? Also, how would you suggest cutting the port for the box? Being that I have to cut through the double baffle and make a perfect retangle box.. Does the port HAVE to be on the double baffle? Rather not cut my port.
i'm trying to build a box for a mayhem 12 thats why i ask....i wonder if that box will work? what do you think?
This box simply can't work with your mayhem 12", this sub needs 1.75-3 cubic feet to work properly.. I could suggest you an enclosure for that sub if you wish.
I use the following assembly style most of the times:
But on 13" is not possible, you would almost cut the baffle in two pieces if you tried.
As do I.. I could give you a higher height.. I'm trying to play it safe being that I made one box and it was to tall, w asn't enough room for the sub to flex.. would have hit the roof.. guess in this case i'd be safe since the sub isn't facing up. Give me one second and I can give you a higher height if your willing?
It can be done as follows with the alternative assembly method:
Enclosure Specifications:
Fb = 33 Hz
Vb = 1.505 ft^3
External Height = 14.25 in
External Width = 21 in
External Depth = 18 in
Port Width = 1 13/16 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 18 7/16 x 12 3/4
Front Internal = 16 15/16 x 12 3/4
Back = 21 x 12 3/4
Left & Right Sides:
Side 1 = 16 1/2 x 12 3/4
Side 2 = 17 1/4 x 12 3/4
Top & Bottom = 21 x 18
L Port Internal Assembly Parts:
Front to Back = 14 11/16 x 12 3/4
Extension = 15 x 12 3/4
Same assembly guide as above:
It can be done as follows with the alternative assembly method: Enclosure Specifications: Fb = 33 Hz Vb = 1.505 ft^3 External Height = 14.25 in External Width = 21 in External Depth = 18 in Port Width = 1 13/16 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 18 7/16 x 12 3/4 Front Internal = 16 15/16 x 12 3/4 Back = 21 x 12 3/4 Left & Right Sides: Side 1 = 16 1/2 x 12 3/4 Side 2 = 17 1/4 x 12 3/4 Top & Bottom = 21 x 18 L Port Internal Assembly Parts: Front to Back = 14 11/16 x 12 3/4 Extension = 15 x 12 3/4 Same assembly guide as above: SD-DB.jpg
Beautiful, mind telling me in a decimal what you put for port width and also what you put for length? I understand 1 13/16 for port length but what's that in decimals?
  • Who's Online   0 Members, 0 Anonymous, 1051 Guests (See full list)
