gogojjt Posted March 18, 2012 Report Share Posted March 18, 2012 well those dd's are beast, so i dont think they would bottom out!!! i wish i could hear the noise to better help ya homie. ill mock up a box with those dimensions and that sub in my program to see what's up with it!!(to see if i get too much port noise) what coils do you have on the sub? only other thing, could be wiring is coming lose on the sub itself and malfunctioning as the volume is increased. you gotta a good amp too, so i dont think that is the problem. Quote Link to comment Share on other sites More sharing options...
BFF Larry Posted March 18, 2012 Report Share Posted March 18, 2012 hold the port and see if the noise stops, or check sub for separated neck joint. my sub would play fine at low volume and as soon as i turned it up, i would get a weird metal clanking sound. the neck joint separated. Quote Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931* Link to comment Share on other sites More sharing options...
herbykw Posted March 18, 2012 Report Share Posted March 18, 2012 I have the same problem. When I go full tilt one o my 4 subs has a loud tapping sound. This just started after I double to power to my subs. I think it is bad lead slap. I bent the leads down a little and it helped, but didn't go away. Quote 06 300C 5.7 Hemi K&N CAI JVC KW-AVX640 6.1" DVD DC Audio 3.5k 6 DC Audio 8"s 6 cubes 8" aero port at 32hrtz http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834 Link to comment Share on other sites More sharing options...
Stee-Z Posted March 18, 2012 Author Report Share Posted March 18, 2012 well those dd's are beast, so i dont think they would bottom out!!! i wish i could hear the noise to better help ya homie. ill mock up a box with those dimensions and that sub in my program to see what's up with it!!(to see if i get too much port noise) what coils do you have on the sub? only other thing, could be wiring is coming lose on the sub itself and malfunctioning as the volume is increased. you gotta a good amp too, so i dont think that is the problem. I dont have any upgraded coils or anything hold the port and see if the noise stops, or check sub for separated neck joint. my sub would play fine at low volume and as soon as i turned it up, i would get a weird metal clanking sound. the neck joint separated. umm.. yeh i played it today and was watching the port on low volume and when it hits mor of low i can hear a slapping kind of noise in the port but i cant reach very far into it since its at an akward angle but me holding it helps it out.... bracing issue?! Quote (4)DD 9918's (2)DC 10k 8 6.5" focals 2 DD SS4 mid amps Audison Bit One processor Jl-cl-rlc line driver iPad in dash Dual Irragi 320a alts 8 batcaps 4000's Second Skin sound deadened Link to comment Share on other sites More sharing options...
