With aeros this can work:
Fb = 35.133 Hz
Vb = 3.627 ft^3
Number of Ports = 3
Pipe Port Diameter = 4
Pipe Port Length = 19 3/4
External Length = 5 3/4
This would make a nice daily setup only, the net volume is larger than you would usually find ina SPL box for those subs, your vehicle is large also so cabin gain would be limited.
what tune is this? with the box only being 20 it woont fit without an elbow, any idea how to get all 3 in there? what is the external lenghth for?
Look at the Fb parameter it's about 35 Hz and check the external length specification, that means 5 3/4" of the port would be external.
Edited by Joe X
i'm new to aero ports, doesnt that negate thir purpose?
Well flanged aeros can sound cleaner than slot ports due to reduced turbulence, also you can change the box tuning easily with them which you may need to compete.
and again thanks for the help, so like the above pic use 3 4" aero ports the the pipe 5 3/4" externallly mounted? to still have usble is there any good way to do a internal port? evev if it was sloted? how much would a slot port take away?
Edited by Terry Zona
ok , i see how this is done, but is there internal tube in the above picture? having the internal and external is throwing me off
There are fully internal, external and mixed.....or you can go with a slot port if you don't like aeros
  • Who's Online   0 Members, 0 Anonymous, 2210 Guests (See full list)
