Go-N-Def Posted March 18, 2012 Report Posted March 18, 2012 if a person has a h/u that has 2 - 4v and one amp for highs two for bass. does the bass amp split 4v. meaning 2v into each bass amp? what happend if theres 6 bass amps.? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
MrSkippyJ Posted March 18, 2012 Report Posted March 18, 2012 voltage is split. i mean this in the nicest possible way, but some questions and answers are really easy to find on google if you can't get an answer on here. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Go-N-Def Posted March 18, 2012 Author Report Posted March 18, 2012 voltage is split. i mean this in the nicest possible way, but some questions and answers are really easy to find on google if you can't get an answer on here. dude i really didnt look. thankz for getting back. can a single be split to much like 10 bass amps 2v output if so whats the best way to defeat that ? Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
MrSkippyJ Posted March 18, 2012 Report Posted March 18, 2012 if the voltage is below the amps minimum, then it is split too much. a line driver is one way to raise the preamp voltage, pass-throughs work also. Really depends on the amps you are using. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Go-N-Def Posted March 18, 2012 Author Report Posted March 18, 2012 if the voltage is below the amps minimum, then it is split too much. a line driver is one way to raise the preamp voltage, pass-throughs work also. Really depends on the amps you are using. thats clear thank u Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
MrSkippyJ Posted March 18, 2012 Report Posted March 18, 2012 no problem. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
