Scion Tc daily driver to show worthy project.
Got the condenser in the car rut before it started raining and hooked up all the ground wires.
That's the ground for the shock tower or to the frame as my research indicated that goes directly to the frame .
This one goes to the valve cover bolt that goes down to the engine block
This one goes to the bolt on the side of the engine block by the alternator
This one goes to the trans casing? It is in back f the starter if I'm not mistaken.
Tis is everything hooked up.. I also replaced the negative battery terminal with another JL Audio terminal. This is NOT the finished product as it started raining on me. I will neaten it up tomorrow.
I used a highly rated but in expensive auto ranging multimeter. The before and after are the readings before and after the buddy club condenser .
Test Before. After. In volts of course.
Battery. 12.38. 12.69
Alternator. 13.61. 13.44
Dist block. 13.18. 13.20
I don't have one that records over time unfortunately.
  • 3 weeks later...
Finally managed to neaten up the wires and run the power wire to the alternator.
I need to get anchors for the front wires. Doctor has me on glucosamine so my hands are not hurting as much.
New measurements with the power cable to the alternator replaced:
Test Before. After. Today
Battery. 12.38. 12.69. 13.72
Alternator. 13.61. 13.44. .......
Dist block. 13.18. 13.20 13.38
ChRge your battery its reslly low youll pick up another .7 volts or so
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
It's not that low though 14.4 is really good, anything above 13 is acceptable. Besides gels tend not to have as good a peak voltage as fully charged liquid battery. But I will charge it can't hurt for sure.
I thoughtbyoure chart was saying your resting voltage was 12.38
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
