ok went to walmart and my car just died in the middle of the parkin lot, first i thought i stalled it, but i relized i was in neutral so i tried to start the car and it just kept turnin over and over, my car is gutted so i have pretty easy access to the fuel pump and i noticed that it wasn't on, so i do the whole stick a paper clip in the main relay to hardwire the fuel pump and it came on, so is it definately my main relay went out, or am i over looking something b4 i blow money on a main relay
it's a 93 civic hatchback with 249,xxx miles
Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? :blink:
How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face :)
mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
fuse possibly?
i wished, lol save me so much money that i already don't have
I've never heard of the paper clip trick...can you be more specific on how you wired it up with the clip?
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
i only know honda's for they are my favorite cars, so i don't know if this works on other cars (i don't even know if other makes have a main relay) but anyways find ur main relay under ur dash and unplug it, for my make and model u would look and the wiring harness and at the plug there are like 6 different terminals so all you do is stick a paper clip into the power terminal and the fuel pump terminal, (5&7 for my car) and basically by unplugging the relay and stickin the paperclip into the terminal u are bypassing the relay and just hardwirin the fuel pump to the battery. by doing this ur checkin to see if ur fuel pump is burnt out or ur main relay went bad.
here are some pictures i have found on tegger.com
these just show how the relay works
these 2 pics show the inside of the relay wit the bad circuit boards
these show wat happens when just one of the solders crack
Edited by KWP369
That's quite interesting...must be an import thing (I'm not being sarcastic)
I've never seen that done before. Studying the diagrams, I would "assume" if this trick worked, yeah your Main relay must be toast. Cause all you would be doing is shorting it out and bypassing it with the paperclip
i guess honda is the only make that uses a main relay so anyways yea, it's the heart of the car and the ECU is the brain lol. so yea i'm just goin to leave it at walmart take out my main relay check all the solders and pray i can just resolder the joints instead of dishin out 130 dollars for a new one. :blink:
