two amps is better than one for many reasons one of my personal reasons is if something was to go wrong with the amp and your not financially able to deal with it right away than your out in the cold on sub action with two you'll always have a way to listen to ya subs unless something goes wrong with both plus more power for later if you upgrade subs or add too what you got it just keeps more options available as far as performance they'll be no major difference in it really sell and get you two that r 1ohm stable for the future
2 Dual 4 Ohms can wire to 1 ohm.
If you can sell one of your 1000.1's for 300, then you have more than enough to pick up an AQ1200D, which does 1200WRMS at 1Ohm.
BASS MEKANIK RECORDS
"Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold!
2007 Ford Focus
(NOTE: My cousin's build I helped him with)
Pioneer H/U
(4) Absolute Dome Tweeters on A & C pillars
Scosche HD683A's in front doors
Fosgate R168x2's in rear doors
SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz
Audiopipe APCL-1800.1D
Q-Mat
Audio Technix 0 Gauge
119aH/850CCA Marine Deep Cycle batteries
YouTube Channel: http://www.youtube.com/DWRhythm
OMG :worthless:
"in the abundance of water, the fool is thirsty" Bob Marley
I have a DC1.2k 1 ohm stability in this Audi A6 pushing 2 dual 4 ohm DClvl3 12's. I wired the subs down to 1 ohm as in diagram. Now that everything is hooked up what do i do w my Amp to get the deepest loudest low frequency bass possible? i would really apprectiate any help on setting my gains. Sub nd Amp Info. thanxx
SUB Info
10" 12" 15" 18" Mounting Depth 6.25" 6.75" 8" 9.5" Mounting Hole Diameter 9.35" 11" 14" 16.75" Outside Driver Diameter 11" 12.5" 15.7" 18.5" Motor Width 7" 7" 7" 7" Weight 20lbs 20.5lbs 21.5lbs 22lbs VC Diameter 3" 3" 3" 3" Displacement .15³ ft .16³ ft .18³ ft .22³ ft Magnet Weight 18lbs 18lbs 18lbs 18lbs Power Handling RMS/Peak 900/1800 900/1800 900/1800 900/1800 Impedance (Ohm) D1/D2/D4 D1/D2/D4 D1/D2/D4 D1/D2/D4 Sd 324cm² 481cm² 823cm² 1217cm² Vas 13.16 liters 28.99 liters 84.88 liters 185.6 liters Cms 0.09 mm/N 0.09 mm/N 0.09 mm/N 0.09 mm/N Mms 190 g 225 g 295 g 305 g Fs 38.5 35.4 30.9 30.4 BL 17.2 N/A 17.2 N/A 17.2 N/A 17.2 N/A Re 3.6 Ohm 3.6 Ohm 3.6 Ohm 3.6 Ohm Le 3.5 mH 3.5 mH 3.5 mH 3.5 mH Qms 7.66 8.33 8.18 8.32 Qes 0.567 0.617 0.706 0.718 Qts 0.528 0.574 0.65 0.661 Xmax 23 mm 23 mm 23 mm 23 mm Ref SPL @ 1 watt 83.1 dB ([email protected]) 85 dB ([email protected]) 87.3 dB ([email protected]) 90.4 dB ([email protected]) Suggested Sealed .65³ ft 1³ ft 2³ ft 4³ ft
Suggested
Ported 1³ ft 1.5³ ft 3³ ft
6³ ft
AMP Info
Key Features
• 1 ohm stable
• Variable low pass filter
• Variable subsonic filter
• Variable bass boost
• Wired remote control
We recommend for installation
• 1 upgraded battery under the hood
• Dash mounted voltage meter
Features Voltage 1.2kw Output Power (RMS) 4 ohm 14.4V 350W x 1 2 ohm 700W x 1 1 ohm 1,200W x 1 1 ohm 16V 1,450W x 1 1 ohm 18V No Input Sensitivity 6V~0.2V Low Pass Filter Switchable ( @ 24 dB Slope) Variable Hz 35~250 Subsonic Filter Switchable ( @ 24dB slope ) Variable Hz 10~50 Bass Boost Variable dB 0-9dB Frequency Response Hz 15-270 Signal to Noise Ratio dB 100 Damping factor 100< Efficiency @ 4ohm % 81% THD @ 4ohms Less than 0.1% Fuse Rating 120 Amps Linked Fuse Rating 240Amps Indicator Power Yes Protection Yes Clip no Speaker & Power terminal Mold Type Yes Power Gauge 4Ga Heatsink Length inch/mm 11.81"/300mm Heatsink Width inch/mm 9.38"/238mm Heatsink Height inch/mm 2.35"/59.6mm
SUB Info
Suggested
6³ ft
AMP Info
Key Features
• 1 ohm stable
are you serious with this fucking post? GTFO...
To the op, Sell em, get a saz2500 or similar... Not a AQ1200 lol
