Sealed Box Project - need advice
1.9 cubes is about perfect for the power you're giving these.
More box builds
I'm with captain stupid.
sweet, thanks for the advice, lets say i wanted to upgrade to the 10inch kicker compVR or VX in the future , would a 2.5 cubed sealed be enough? (for 2 of them). i wouldnt mind being able to reuse the box :) ( im on a budget, college student and whatnot. i was lucky to get these subs and amp for cheap anyway :P)
Edited by kreator_destruction_sodom
if you were powering them to max potential, then about 1 cube net each would be pleeeenty.
but i think you need to open your mind a little bit. if you were gonna upgrade, there are many other brands out there that are better than kicker and are cheaper too.
also, with all the room you have, i'd say just go ported. it's not very difficult to make and sounds better than sealed IMO. even on death metal like you listen to
More box builds
tune to 36, keep about 12-14 inches per cubic foot of port area, make a box that's about 2.5-3 cubic foot net, look at the physical port length and model it in sketchup so the port keeps the same width throughout.
download torres calculator in the subwoofers/enclosures section.
download google sketcup (just search it)
if you want a foundation on how to do everything, i've got a ton of pictures on my facebook page that you can reference.
More box builds
any links to websites where they explain port area/port length? i understand port area( dont understand how its calculated) , port length i dont understand either.
damn if only you took EMT i would have already paid you to design me one :P
going thru torres calculator now to try to figure this all out..
Ok in case you decided to go ported, here is a suggestion based on kicker's spec and in your dims also better port area and ok for use on rated power:
Enclosure Specifications:
Fb = 36.7 Hz
Vb = 3.5 ft^3
External Height = 14 in
External Width = 33 in
External Depth = 20 in
Port Width = 4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 33 x 14
Left & Right Sides = 18 1/2 x 12 1/2
Top & Bottom = 33 x 18 1/2
L Port Internal Assembly Parts:
Front to Back = 14 1/2 x 12 1/2
There is an alternative assembly method in case you don't want to cut the port through the baffle.
Edited by Joe X
so this is the first ever woofer box that me and my friend assembled, it was a good learning experience, box dimensions were as follows
12inch height
30 inch width
20 inch depth
3.2 cubic feet
port specs
3.5inches width
10.5inches height
internal port length (21.75")
giving me a tuning frequency of 36hz
port area per foot = 15.91 inches2
3/4 inch mdf used with wood glue on all joints with pilot-drilled wood screws. then silicone on the inside, Big credit to 412 CVX for helping me out on how to properly design this box :). and now the porn .
sorry for the monster size pics :P , first phase just getting the panels all lined up for test fitment
walls and port walls are in :)
clamps in this pic are just holding the smaller port wall in place while screws are being drilled in to lock it in place , also woofer cutouts have been measured out so they are spaced apart nice and evenly!.
woofer holes cut out, you can see the previous day we decided to put silicone on the joints a bit early :P,
getting ready to put the final piece in!!!, terminal was screwed into place and siliconed, we had to use a dremel to shorten the screws we were using so it wouldnt go all the way through the mdf for the terminal cup.
ALL DONE!!
now i have to wait until tomorrow evening to put subs in and try my new box out!! :)
btw this will be going in the trunk of a 2009 toyota yaris sedan.. lol
powered by a mtx tc3001 mono d amp, both subs are SVC 4 ohm 10inch Kicker COMPs , wired for 2 ohms as the amp puts out 300watts RMS at 2 ohm
cant wait to hear some slayer and arch enemy from this new box .
  • Who's Online   1 Member, 0 Anonymous, 454 Guests (See full list)
