box spec double check/suggustions
i like that one alot better :)
theyre dc level 4 m1's
Edited by pa-pa-platypus
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
m1 lvl 4 15's on a 3.5k clamping 900watts, BUT i plan on keeping the same box when i drop back down to .5 and clamp 4300 roughly out that bitch, think thatll cause huge problems? and does anyone see loading issues with this box at all? subs would be all the way to the back towards the hatch
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
shouldnt...might be a little on the big side..id put the subs to the back of the box (furthest away from the port)
power: dd m4
but then everythings just loading into the port? thought thats what you DONT wanna do? and yeah i just thought about that, i need to shrink it a bit
much better i think...
Edited by Freshman6969
either way of position the subs should work..just them at the back of the box the subs are furthest from the port and allow for a better loading..but either way works really shouldnt have loading issues either way.. and i like that one the best..
power: dd m4
  • Who's Online   1 Member, 0 Anonymous, 438 Guests (See full list)
