iceman1575 Posted March 26, 2012 Report Posted March 26, 2012 I'm thinking about adding a second battery to my truck. If I can get a single battery that can handle starting/2000 watts of stereo, then that would work better. But if not, what's the easiest way to mount a second battery in the front of my bed & run it into the cabin? I'll probably run either 1/0 or 2/0 from front to rear, and 1/0 into the cabin...Any tips & tricks would be greatly appreciated! POTATO!
ZombieFatMan Posted March 26, 2012 Report Posted March 26, 2012 Basically you'll just put a battery in line of your power wire from your first battery but also have another fuse there just in case it will be grounded to your frame and then from that battery you'll run the power to the amp That's short and sweet version. you can find plenty tutorials here on exactly how to do it . just make sure you have a seal battery like kinetic or even a Yellowtop Optima You can get a battery box from your local hardware store or auto parts store the kind that holds a battery for a boat I will keep it nice and tight then you can just mount it in the corner of your bed of the truck "Walmart Where Car Audio Is Both Funny and Sad" "The weak are meat, and the strong do eat..."
Derek Hathaway Posted March 27, 2012 Report Posted March 27, 2012 Get an isolator...always have ur starting battery charged;)
01ExSport Posted March 27, 2012 Report Posted March 27, 2012 I've always thought of isolators as kind of a waste, just don't bump for 5 hours with your car off and you'd be fine
SnowDrifter Posted March 27, 2012 Report Posted March 27, 2012 You don't need isolators If anything, it makes it more of a PITA because you have to hook up your charger 2 different times And it's another expense And it's just something else to worry about ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
