XS Power
besides the price of thess battiers and the slight ah rate whats the difference??? let me know fellas!
xp3000 can't be used under the hood, doesn't have the thick casing like the 3100. XS said the 3100 is better if your strictly competing, but for daily they would recommend the xp3000. They said if you had a bank of equal amounts of each, you wouldn't really be able to tell the difference
Team Flex Issues
straight from xs
Unless you are in a competition class where you are limited by batteries and burping, then you will probably never notice a difference to be honest with you. The XP series turned out to be stronger than we originally though they would be when we designed them. If you have a battery bank of D3100s and a bank with the same number of XP3000 you probably will not see much of a difference.
Yes, you can run the D or S series under the hood and the XP series in the back with no issues. That is kind of what we had in mind when we designed the new XP Series. Most people complain about the price on the D3100, so we offered a battery (XP3000) that will run neck and neck with it at a $50 lower cost.
Team Flex Issues
so with a xs power d3400 under the hood and 3 xp3000 in back bank is fine???
or should i stick with the d3100 cause of the d3400?
Edited by wwjm
  • Who's Online   0 Members, 0 Anonymous, 1471 Guests (See full list)
