it comes out to 4850w rms. with the 2) sub amps at 1ohm and the other 2) comp amps at 2ohms. i wasnt sure if 2 yellows could handle that kind of load. imma go check out some of the xs batteries now, thanks again
optimas aint even designed for car audio use.. they were designed for offroad guys who run many lights and wont have to worry about acid leaking
trying to run 5k on 2 yellowtops is asking for failure..
more like a SOLID 250 300amp alty and 2 BIG batteries in the back at least
I'd get the biggest XS you can fit under the hood. And 2 XP 3000s or D3100s in the back....no point in going all the way to half-ass. If you cut corners, you will regret it later.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
after taking things into consideration, time/ money/ knowledge, i plan to run a 250a alt, do the big 3 in 1/0, a D3100 (biggest i can fit) and runnin it parallel with another D3100 in the trunk. i dont see why this wouldnt work just fine. worst comes to worst i slap another battery in the back if my voltage drop is too much. sound like a good plan?
  • Who's Online   0 Members, 0 Anonymous, 1021 Guests (See full list)
