Hi All Whats Goood?
Im keep is simple, I am looking for subs 2 12" d4 or D2's? not sure yet
Sa-12 i know are 600w
ReSex12 are 600 w
What would be a better choice?
Running ina Cartunes custom Box ( currently have 2 JLw6's Half Burnt.... )
Running a NEW 1000/1d
Specs
  • JX Series 1-Channel Class D Car Amplifier
  • RMS Power Rating (@ 14.4V):
    • 4 ohms: 500 watts x 1 chan.
    • 3 ohms: 750 watts x 1 chan.
    • 2 ohms: 1000 watts x 1 chan.
    [*]Unregulated PWM switching type power supply
    [*]Remote bass level input (JL Audio RBC-1 sold separately)
    [*]LED power (green) and protect (red) indicators
    [*]Variable Bass Boost (0 to +12 dB bass boost centered at 45 Hz)
    [*]Soft start turn-on prevent clicking and popping when system turns on
    [*]1 channel operation
    [*]Speaker-level (high-level) inputs with signal sensing for automatic turn-on
    [*]Preamp RCA outputs to daisy chain multiple amps
    [*]3-Way System Protection circuitry (thermal, low impedance, and speaker short protection)
    [*]Heavy duty aluminum alloy heatsink for effective heat dissipation
    [*]Nickel-plated RCA level inputs
    [*]Nickel-plated screw terminals
    [*]Input sensitivity:
    • Low level: 200mV-4V
    • High level: 2.0V-10V
    [*]Variable low-pass filter (50-200 Hz, 12 dB/octave)
    [*]Damping factor: >1000 @ 4 ohms
    [*]Frequency response: 20-150 Hz (+/– 1 dB)
    [*]Dimensions: 11"L x 7-3/4"W x 2"H
    [*]Brand New
    [*]3 Year Warranty
What sub should i go with? Im a jerk so i like to be LOUD! Also Will any of the above handle a 2k watt amp? Without Cookin em?
Hi All Whats Goood? Im keep is simple, I am looking for subs 2 12" d4 or D2's? not sure yet Sa-12 i know are 600w ReSex12 are 600 w What would be a better choice? Running ina Cartunes custom Box ( currently have 2 JLw6's Half Burnt.... ) Running a NEW 1000/1d jx10001d2.jpg Specs
    [*]Unregulated PWM switching type power supply [*]Remote bass level input (JL Audio RBC-1 sold separately) [*]LED power (green) and protect (red) indicators [*]Variable Bass Boost (0 to +12 dB bass boost centered at 45 Hz) [*]Soft start turn-on prevent clicking and popping when system turns on [*]1 channel operation [*]Speaker-level (high-level) inputs with signal sensing for automatic turn-on [*]Preamp RCA outputs to daisy chain multiple amps [*]3-Way System Protection circuitry (thermal, low impedance, and speaker short protection) [*]Heavy duty aluminum alloy heatsink for effective heat dissipation [*]Nickel-plated RCA level inputs [*]Nickel-plated screw terminals [*]Input sensitivity:
    [*]Variable low-pass filter (50-200 Hz, 12 dB/octave) [*]Damping factor: >1000 @ 4 ohms [*]Frequency response: 20-150 Hz (+/– 1 dB) [*]Dimensions: 11"L x 7-3/4"W x 2"H [*]Brand New [*]3 Year Warranty
Sorry.. maybe I'm missing something here but where are you getting 2k watts from? Do you have another JL amp? 1000w @ 2 ohms is biggest I see..
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
They take 900 watts of clean power all day long without getting anything more than luke warm
1200 watts is pretty good for them. They get a bit on the warm side after some hard playing, but no coil burn or anything.
SA's can handle over rated, but it has to be clean power. The JL won't put out 2k for sure. I would say SA only because I've heard more about them than RE but I haven't delt with either hands on so I honestly couldn't tell you. Also there are no VS threads on the forums so just watch how ya phrase things the best for your situation :P
will this amp (jl) push them ok? or should i upgrade? if so what should i use to push em? should i go with d2's or d4's? btw the box is ported how should i wire them?
Edited by Jimi Schnau
Your wiring depends on the amp's configuration if it's 2 ohm, or 1 ohm stable. You will need a new amp, just as a suggestion. Not hating on your JL but there are many other brands that you could get would be tons cheaper and push the same amount, with the same quality. Sundown, DC, Audio que ect.
well than just get another JX 1000/1 if you want more power. JL amps are good. but yea for the money there are other brands that will give you plenty of power. but if you wanna stick with your JL amp your gunna have to make a choice. personally, id get D2 subs so you can wire them at 2 ohms now for your JL amp. if oyu want more power down the road, sell the JL amp and get audio que or a solid amp and run at .5 ohm nominal and after box rise you will be at 1 ohm hopefully or a lil more and you be golden. look at a 1500 watt amp if your looking to do that. but i would suggest some experience before you wire to .5ohm. need to do electrical upgrades and make sure your box rise puts you at 1 ohm. but do the JL amp with 2 D2 subs for now if you like that amp.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
any shops around michigan? that sell AQ? im Downriver south of Dtown? I notice ur from AA
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
