HunterJohnson Posted March 30, 2012 Report Posted March 30, 2012 Thought I knew alot about stereo but im STUMPED! I put my sa-8 and mrp-500 into my brothers 99 camry. Wired it with 4 gauge KnuKonceptz OFC kit Gains set to the middle Low Pass filter at 100hz Head unit is Sony Xplod mex-bt3700u The amp is turning on the subwoofer is playing just a tiny bit louder than the 6 x 9's in the back. I plugged the RCAs into my amp in my car and the alpine/sundown worked just fine. So it is either a headunit problem or an RCA problem. The back of the sony has subwoofer preouts that are black without indication of right or left. I turned the HU to max volume and I also turned all the eq settings to max and still the sub is a tiny bit louder than the 6 x 9's. Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
HunterJohnson Posted March 30, 2012 Author Report Posted March 30, 2012 Anyone have an idea? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
01ExSport Posted March 30, 2012 Report Posted March 30, 2012 Incredibly weak preouts? Did you turn up the bass, or the SW preout? All I have for suggestions about now, lol. What's you subsonic at?
HunterJohnson Posted March 30, 2012 Author Report Posted March 30, 2012 Thats my guess is weak preouts. You think the HU is not working right? and the mrp500 is a set subsonic filter (15 Hz, 24 dB/octave)...isnt it? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
01ExSport Posted March 30, 2012 Report Posted March 30, 2012 not sure on the subsonic, haven't dealt with many alpine amps, the H/U has 2v preouts. hmmm.... And did you check if the headunit has any lpf turned on?
jrchevy87 Posted March 30, 2012 Report Posted March 30, 2012 i think theres a sw setting on the headunit, i know a buddy of mine had that problem on his xplod(dont remember what model), his was 2 rca's out one front and one rear/subwoofer and he had to set it for subwoofer to play anything Jeep Wrangler TJ Hardtop Build
HunterJohnson Posted March 30, 2012 Author Report Posted March 30, 2012 I turned the lpf off, on, nothing works. The subwoofer is on at max, +10db I looked on the mrp500 manual and it said 4v RCA, so I think the sony isn't putting a strong enough signal to it. What is the cheapest way to go about fixing this problem. Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
c.director Posted March 30, 2012 Report Posted March 30, 2012 I turned the lpf off, on, nothing works. The subwoofer is on at max, +10db I looked on the mrp500 manual and it said 4v RCA, so I think the sony isn't putting a strong enough signal to it. What is the cheapest way to go about fixing this problem. Line driver. Don't know if that's your problem though. Facebook: http://www.facebook.com/caleb.arnold.9809 YouTube: http://www.youtube.com/user/CustomAudioChannel?feature=watch
01VWGREENMACHINE Posted March 30, 2012 Report Posted March 30, 2012 how many preouts are on the hu do you have the rcas going directly from hu to your amp?? http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
HunterJohnson Posted March 30, 2012 Author Report Posted March 30, 2012 I turned the lpf off, on, nothing works. The subwoofer is on at max, +10db I looked on the mrp500 manual and it said 4v RCA, so I think the sony isn't putting a strong enough signal to it. What is the cheapest way to go about fixing this problem. Line driver. Don't know if that's your problem though. Thats the only thing that makes sense... Thinking bout buying another cadence eq like that one I have http://www.sonicelectronix.com/item_41255_Cadence-CEQ-773.html#tabs Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
