Kiean123 Posted March 31, 2012 Report Posted March 31, 2012 When I put an MB Quart ONX 1.1500D in the 2005 Acura RL, will it need another battery or is stock fine?!.. The amp will be running at 1500 watts at 1 ohm. I will also have an ONYX 4.125 in the vehicle if that takes juice from the electrical too. The Specs say the maximum alternator capacity is 130 (amps) for the RL. If I do need another battery, what brands are quality/decently cheap? wooohoo! -Acura RL 2005. Blue. -Stinger Expert Roadkill..Trunk only -(2) Skar VVX-12's D4 coils -Dual slot ported to the left custom box tuned @ 32hz -Audioque 1200D amplifier A tribe called quest... ftw
Kiean123 Posted April 1, 2012 Author Report Posted April 1, 2012 wooohoo! -Acura RL 2005. Blue. -Stinger Expert Roadkill..Trunk only -(2) Skar VVX-12's D4 coils -Dual slot ported to the left custom box tuned @ 32hz -Audioque 1200D amplifier A tribe called quest... ftw
Kiean123 Posted April 2, 2012 Author Report Posted April 2, 2012 So yes? or no I will be fine? wooohoo! -Acura RL 2005. Blue. -Stinger Expert Roadkill..Trunk only -(2) Skar VVX-12's D4 coils -Dual slot ported to the left custom box tuned @ 32hz -Audioque 1200D amplifier A tribe called quest... ftw
Kiean123 Posted April 3, 2012 Author Report Posted April 3, 2012 shizzle wooohoo! -Acura RL 2005. Blue. -Stinger Expert Roadkill..Trunk only -(2) Skar VVX-12's D4 coils -Dual slot ported to the left custom box tuned @ 32hz -Audioque 1200D amplifier A tribe called quest... ftw
Emmet Posted April 3, 2012 Report Posted April 3, 2012 When I put an MB Quart ONX 1.1500D in the 2005 Acura RL, will it need another battery or is stock fine?!.. The amp will be running at 1500 watts at 1 ohm. I will also have an ONYX 4.125 in the vehicle if that takes juice from the electrical too. The Specs say the maximum alternator capacity is 130 (amps) for the RL. If I do need another battery, what brands are quality/decently cheap? Really? What do you think it would run on? Hopes and dreams? Those 2 amps would be pushing it a bit, if that amp does actually put out 1500 watts thats a little over 100 amps draw full tilt... your car needs juice too, aswell as your other amp, good cheap batteries would be like c&d 102 ah or deka 9a31`s. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
KOZ89 Posted April 3, 2012 Report Posted April 3, 2012 i'd go with another battery, possibly a lower range, not saying it blows, but should do the trick http://compare.ebay.com/like/360436990331?var=lv<yp=AllFixedPriceItemTypes&var=sbar or http://www.ebay.com/itm/SHURIKEN-METRA-SK-BT45-1250-WATTS-45AH-CAR-BATTERY-/160611956256?pt=LH_DefaultDomain_0&hash=item256537f620 its really a preference on how you will wire, if you will actually do the BIG 3 which is re doing the electrical from alt to battery to w.e else you need it going to (amp - 4 chan. mono, other electrical such as lights , etc. etc. .....) build coming late April, early May build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/ 1997 Dodge Ram 1500 Slt Laramie Amplifier - AQ3500d.1 Sub - DC LVL 5 18" Highs - (2x) Selenium ST-350 Super Tweeters 8ohm Mids - Selenium 6" 200w midrange 6W4P (pair) Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch Wiring - XP Flex 25' Red, 25' Black Alternator - Mechman 270amp Battery - XS power D3100, 1- Yellow top front more to come...
Kiean123 Posted April 3, 2012 Author Report Posted April 3, 2012 Okay, thanks Emmet, dumb question the way I worded it lol.. I was trying to say if it took SIGNIFICANT juice! The electrical in my car is pretty good though so I was double checking.. I'm looking at the batteries now just seeing if I need 12V or 14V and how much I'm going to spend. Will this be plenty? http://compare.ebay.com/like/360436990331?var=lv<yp=AllFixedPriceItemTypes&var=sbar wooohoo! -Acura RL 2005. Blue. -Stinger Expert Roadkill..Trunk only -(2) Skar VVX-12's D4 coils -Dual slot ported to the left custom box tuned @ 32hz -Audioque 1200D amplifier A tribe called quest... ftw
