SnowDrifter Posted April 1, 2012 Report Share Posted April 1, 2012 Looking for ideas on the box size/tuning point I keep hearing people saying to do a big box tuned high. But when I modeled 6.5 cuft @ 37hz, it gave a really peaky response according to winISD But when I plotted 5 cuft @ 32hz, it seemed to give a reasonable response. Ideas on this? Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Guest Posted April 1, 2012 Report Share Posted April 1, 2012 dont tune that low with aq woofers unless you want to lose some higher end output and want to be able to play down to like 25hz or something. every setup i heard with aq woofers that were tuned to mid 30's played low 30's and high 20's quite well. winisd doesnt really take into account of well...anything. in regards to space that is. when you put that box in your car the low end will increase significantly and the overall graphed response will change. i may be wrong on some of this, i may not. i dont have any personal on hands experience with aq woofers. im just going by what i've heard time and time again from multiple people. Quote Link to comment Share on other sites More sharing options...
412 CVX Posted April 1, 2012 Report Share Posted April 1, 2012 The plots on winisd are not very reliable, shit changes when you put it in a car. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 1, 2012 Author Report Share Posted April 1, 2012 That's what I'm trying to figure out. Here are the 2 different response curves I am getting Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Guest Posted April 1, 2012 Report Share Posted April 1, 2012 winisd doesnt take into account real world applications. it just takes your box and sub setup and puts it outside on your driveway with a mic a foot in front of it and measures the response. once you put it in your car, everything is going to change. just do 35hz. thats the lowest i've seen recommended for those woofers. sure people tune them lower, but thats because they typically want a low end monster. Quote Link to comment Share on other sites More sharing options...
412 CVX Posted April 1, 2012 Report Share Posted April 1, 2012 Read that quote in your signature. WinISD is just theory that doesn't take into account cabin acoustics, people who have experience with the sub say tune higher, bigger box. Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
KOZ89 Posted April 1, 2012 Report Share Posted April 1, 2012 i would try something like this, although i don't have any information of woofer displacement so i made up one close to what i believe your sub might have. Quote build coming late April, early May build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/ 1997 Dodge Ram 1500 Slt Laramie Amplifier - AQ3500d.1 Sub - DC LVL 5 18" Highs - (2x) Selenium ST-350 Super Tweeters 8ohm Mids - Selenium 6" 200w midrange 6W4P (pair) Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch Wiring - XP Flex 25' Red, 25' Black Alternator - Mechman 270amp Battery - XS power D3100, 1- Yellow top front more to come... Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 1, 2012 Author Report Share Posted April 1, 2012 No idea what the cabin peak on this is. But the vehicle this is going into will be a 1997 2 door chevy tahoe Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
412 CVX Posted April 1, 2012 Report Share Posted April 1, 2012 what kind of power will this be seeing? Quote Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid. Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 1, 2012 Author Report Share Posted April 1, 2012 Should be right around 2k, maybe a tad less. Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
