Box design help
NLMax
I need help to design a box because i know nothing about "Torres Box Tuning Calculator"
And it's all pretty difficult for me because English is not my best language.
Max dimensions are 60H x 75W x 45D. all in centimeters.
Subwoofer: Sundown SA-15
amplifier: Sundown SAZ-2000D
So, Who can help me to design a box?
_____________________________________________________
Sorry for my bad english, I'm from The Netherlands
Kind of difficult to come up with a spec in metric units, also that is a powerful amp, I gave you tight volume on the box to help protect the sub but you should engage the subsonic filter of the amp and set it to around 30Hz:
Enclosure Specifications:
Fb = 35.017 Hz
Vb = 3 ft^3
External Height = 45 cm
External Width = 69 cm
External Depth = 45 cm
Port Width = 7 cm
Cut Sheet List:
* All Dimensions in Centimeters.
* Wood Thickness is 18mm for all Parts.
External Enclosure Parts:
Front & Back = 69 x 45
Left & Right Sides = 41.45 x 41.45
Top & Bottom = 69 x 41.45
L Port Internal Assembly Parts:
Front to Back = 34.45 x 41.45
Extension = 21.15 x 41.45
This is how parts assemble:
Wood thickness is set to the nearest metric equivalent of 3/4" normally used in boxes which is 18 mm.
Let me know if you can't find 18mm wood, if you have the D4 version also let me know.
  • Who's Online   0 Members, 0 Anonymous, 1036 Guests (See full list)
