Get the biggest made for your vehicle or at least the biggest you can afford.
Agreed! A good rule of thumb is to use the largest alternator you can fit on the engine and an additional battery for every 500 watts of amplification.
well, im confused a little b/c i heard other wise. If u get a big alternator, it still will have problems charging when car is not moving. front what i understand from research, i heard its actually better to go w/ multiple alternators. please leave comments and advice
thx
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
thx
the only thing with a multiple alt setup is although all the HO alts have a low idle they are all combine and you'll see more amps at idle until you start bangin it.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
