I was sagnificantly louder on the meter when I had sub up, port back. It's what I would suggest for your vehicle. May I ask why you only have 13inch hight though? I pulled off 16.5inches the seat and window line.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Yeah man, I'm planning on sub up, port back. There might be a difference between generations, mine is the generation of Outback after yours, but I want to be able to slide the box all the way against the back of the seat and be able to slide the cargo cover over it. There's only about about 15 inches to play with under the cover. But I think it is about 16.5 to the window line, so they must be similar.
Do you have a build log so I can take a look at your box? I'd really like to see it.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Ok.
I just did some more measurements and made some considerations. I think I'll can the original idea, and go with a box with a more traditional port orientation.
I'm thinking 24x13.5x29.5 Port internal and to the hatch. Sub up, toward the rear of the box, above the port. It looks like I'll be able to get up to about 6in. between the port and hatch. So I guess that's that, unless someone comes up with something else before I start cutting wood.
Thanks again to everyone for their input. Anymore input is also welcome!
John, I appreciate the effort your putting into trying to convince me to use a slot port. But I'm not going to use a slot port this time.
I'm pretty set on the Aero, so that's what I'll be using. :good:
I can shrink the box slightly to 24x27.5 And I end up with a port ratio of 7.94:1 That might be better. Net volume drops to just under 3.6.
Ah, it may be different in your Outback. Unfortunately I don't have a build log. I wish I did :/
Good luck with everything though, those aeros should make your box pretty efficient.
(1) Mechman 240
TEAM NWSPL
155db outlaw
That's too bad man. I guess I can't blame you seeing as how I don't have a build log either.
Thanks for the luck though, I'll need it. I think it'll work out pretty well.
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
