Hi I have an old memphis power reference 12 and I can't find any enclosure recommendations I can find the specs and everything on their site but nothing about enclosures. I have it in a prefab box right now I know I know. That's why I want to find the recommendations so I can build my own box so if any of you have built a box for one and remember the dimensions that would awesome or know where I can find them I would be greatly appreciative thanks.
I have a ford explorer so space isn't to much of a concern and right now I'm running a pioneer 760 the specs say the amp does 380 x 1 bridged at 4 ohms.
Any suggestions on how many cubes I should need? It does pretty good in the prefab box it shakes the whole damn truck on that little amp, but I'd like to get the most out of it I can.
Edited by trpkkd
Ok here is a siggestion based on Memphis spec, use Torres calculator to make your own spec or build as follows:
Enclosure Specifications:
Fb = 35.031 Hz
Vb = 1.9 ft^3
External Height = 14 in
External Width = 28.25 in
External Depth = 15 in
Port Width = 2 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Top & Bottom = 28 1/4 x 15
Left & Right Sides = 13 1/2 x 12 1/2
Front & Back = 28 1/4 x 12 1/2
L Port Internal Assembly Parts:
Front to Back = 11 1/4 x 12 1/2
Extension = 12 x 12 1/2
Assembly guide (generic dimensions):
Let me know any questions.
Do you think I should build it sub up port back like the picture?
Yes. Its an suv
If you wanted to learn the Torres calculator I can also answer your questions.
Edited by Joe X
