I am not sure on all of the details because i had it installed by someone (professionally)
when i hit the remote start button my car starts but then immediately shuts off. after about 20 seconds my remote tells me the car has shut off. then i can hit the button again and it starts normal
this sequence causes my check engine light to turn on as well but it clears itself if i do not use the remote start feature.
any idea what could be causing it? everything else works fine
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
take it back and have them reprogram the moduale, do you know if they ran a tach? or if its tachless? tachless usally causes issues like that, its one of the two im sure of it
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Guessing ford or chevy.
Its a key bypass issue.
Easy fix but need all the details
Could be tach if it wasnt throwing the code *cel
That instantly tells me bad key bypass
Mopar
05 Dodge Magnum
what all info do you need?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Lol.
Nothing to do with the alarm used.
*facepalm*
Ahhh
Do you know what module they used?
Are you capable of doing the fix?
Ahhh
ch-all with the chth2 t harness
and possibly
Edited by IH8PunkRok
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
