few things to look at, for one, check the ohm load exactly, its one of those things that actually matter in this situation.
for two, dont measure the voltage on the dash, its rather in accurate and does not measure the amps voltage, which is actually lower than the voltage at the front of the vehicle.
third, make sure the amp can breathe, if its closed off from circulating air its going to have a hard time cooling off.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Found out what it really was I belive. Ohm load
But still doesn't make sense that it would only protect when car was on.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
it might be because more current changes the ohm load.
Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car.
It's probably cause the amp is seeing like 10 volts with the car off. I'm not sure on technically why that matters, but 10 volts is never good
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
  • Who's Online   0 Members, 0 Anonymous, 561 Guests (See full list)
