i have an 01 cavy, and will be walling it soon. how did you secure your false floor to the car?
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
the floor is just sitting in place, its not going any wear with the weight of the box and its wedged in there. I have a 4x6 about 3feet long sitting on the hump then I cut some 3/4 plywood and screwed it to the ends as legs ( Oh I have pipe strapping holding the ends of the 4x6 to the floor) then made spacers out of 3 layers of 3/4 plywood and screwed it to the front corners of the base and screwed the base to the 4x6 and I have 2 rods holding the back of the box to the brace behind the seat wear the plastics used to b when the seats were folded down
http://www.stevemead...new-xfl-pg6-57/americanbass hd 12d22 audiopipe 1800.1ppi s580.4rockford p1653 frontpolk audio 6x9 rearbig 3
How big is that box? It does not look near big enough...
Build In Progress!
2000 V6 Mustang
H/U - JVC KW-ADV64BT
8 - P3D212's / 14cu. ft. / 34hz
Front - T1675x2, PPS4-8x4, T1TSx4
Rear - T1675x2, T165x2
Sub Amps - T2500-1bdCPx2
Mids/Highs Amps - T600-4x2
3SIXTY.3 Signal Processor
51Ft. RF 1/0 Spool x 2
Excessive Amperage 300amp Alternator
VMAX CT2500 x 2
Optima Yellowtop
