Doodcody's 4 lvl4 15's 148.3 at first show
do you think this is enough room for the ports to breathe? its 7" from the box to the hatch top to bottom and this width is 44". Im really hoping this isnt suffocating the ports=/
You should be good
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
I could but I dont want to, it would be really inconvenient and i wouldnt want someone accidently to hit it while in my car, if its behind the seat between the box its out of the way, the 175.4 will end up being under the box( thats the plan right now) and the batteries on the side so we will see
Grease up a shoehorn and make that shit fit lol
i need help i'm a soldier and i just got back from my 7th tour in afghan and before i deployed i told the wife i was going to get me a system when i get back but when i came back she had already bought me speakers and amps the speakers are 4 18 inch dd audio 9500 and 4 ddaudio amplifiers the m4 i don't know anything about specs on an amp can you explain this for me Bridged NA Channels 1 Cont Power at 1 Ohm 5200W x 1 @ 12v Cont Power at 2 Ohm NA Cont Power at 4 Ohm NA Damping Factor >150 Dimensions (Inches) 27.625L x 9.13W x 2.5H Dimensions (Metric) 702L x 232W x 63.5H Dynamic Power 9500W Efficiency Thru Output 87% Input Sensitivity 0.15v - 5v Shipping Weight 36 lbs S/N Ratio >100dB Tested THD ≥1% Tested Voltage 12v -14v Variable Bass Boost 0-6dB @ 45Hz Variable High Pass Filter NA Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
If you put the 175.4 under the box, MAKE SURE that you have a fan on it and it is elevated off of the floor. It will over heat if you dont.
hey man feel free to post this in the amp section and youll get more help, thanks
