94-04 mustang install HELP!!
got two questions
1. where in the hell can i get a good ground in or around the trunk of a 2000 Mustang
and
2. The big 3 on it... got the power for the alt to the battery and the ground right next to the battery on the nose... what would be the 3rd
1 try and peel back the carpet and ground it to the sheet metal
2 engine block to ground is how I was always taught
~This is added to the post you have just read:
I appreciate everything you guys do, and I hope you understand how much it matters to have people like you helping me learn
thanks so much
~Check my youtube for my music and my car audio: http://www.youtube.com/1ohmstable
~Rip dustin 7-11-09
Memorial build log: http://www.stevemead...memorial-build/
ground, strut tower. goes directly to frame. only ground better is literally the frame itself.
Don't bother adding the ground from the battery to your engine, the OEM ground is sufficient for engine operation.
Add a ground directly from your alternator or alternator mounting bolt to the battery negative.
Add a ground directly from your battery negative to bare metal on your chassis.
Add a charge cable directly from your alternator output stud to the battery positive.
From there you can connect your audio or secondary batteries. I prefer to ground the amps directly to the battery. In the instance of multiple batteries it's best to ground the battery to chassis and directly to the primary battery.
It's all about the path of least resistance.
  • Who's Online   0 Members, 0 Anonymous, 1765 Guests (See full list)
