Josh Reynolds Posted April 13, 2012 Report Posted April 13, 2012 I had a RF r250-4 insalled yesterday at a local audio shop and also a pair of RF p1693 speakers put in the front doors. I have Infiniy Reference 6x8s in the rear. After the insall the first thing I noticed was how it lacked clarity horribly, the factory unit sounded much better. Then I tried to fade the signal to the rear to see how the Infinity speakers sounded but when I did all I got was output from the sub. I faded to the normal center and i get siganal out of the front, rear and sub. So i listened to it from the back seat and the infinitys seem to be clear. BTW the infinitys are 2ohm and the RFs are 4ohm, and i still have the factory head unit. Could it be they only used 1 hi/low or is the resistance differnce? I really have no idea.
Robert8252 Posted April 13, 2012 Report Posted April 13, 2012 Post a pic of the amp where the speaker wires are hooked up and rcas 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
vibrator Posted April 13, 2012 Report Posted April 13, 2012 try fade to front and see if all the speakers work. they may have wired the fronts and sub to your 4chan and your rears to your sub? Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car.
Team Bassick - Kimo Posted April 13, 2012 Report Posted April 13, 2012 Sounds like you have a bunch of things that could be wrong. First off what is the vehicle and stock system. Today's premium system's are very well tuned and sound great to start off. If it is basic or an older vehicle then upgrading will almost always be beneficial. Now are the subs being powered from the 4 channel as well? from your fading issues sounds like it is. You also mentioned a center channel. which needs its own channel as well. so you have two big issues one you may not have enought output on your head unit to accomodate all the speakers and two you don't have enough channels of amplification either. Bottm line need a little more information. KIMO @teambassick http://www.teambassick.com
Josh Reynolds Posted April 13, 2012 Author Report Posted April 13, 2012 I'm at work right now but as soon as i get to my car I'll post one.
Josh Reynolds Posted April 13, 2012 Author Report Posted April 13, 2012 It's a 08 Ford Focus and i kept the stock reciever becuase i would lose everything in my dash and it sounds decent. What I meant by center was the middle of front and rear, he normal position i guess you would call it. The 4 channel is only running the 4 full range speakers, i have the RF r500-1 powering my sub.
863JOE Posted April 14, 2012 Report Posted April 14, 2012 I vote checking the x-over setting at the amp. 2010 Altima Coupe Kenwood DNX9990HD JL C5 components Rockford T1692's JL HD600/4 JL HD 750/1 JL 12W7AE 2.5 cubes @ 33hz
m&c caraudio Posted April 14, 2012 Report Posted April 14, 2012 The shop probably used the front two channels of your stock hu for your four channel off one hilo and another one on the rear channels for your subs. I do that all the time at the shop that I work at. Try tuning the crossovers on your amp .
