How To: ELD Bypass for Honda Civic/Accord/Fit
this just lets you have good voltage with the car off, thats what it sounds like
Uhh no? The eld is used when the car is running.
No. The eld is a controller. It tells the alt how much voltage to produce. The mod disables this controller and allows the alt to charge at its highest set point voltage. Aka 14.4
The ELD controls when the computer switches the alternator into H.O. mode, the bypass lets YOU control when the alternator goes into H.O. mode. The ELD is designed to reduce the alt output so it will put less stress on the engine. It's a Honda thing, they do this to make it run more efficient and get better gas mileage.
Ninja'd by the Llama :ninja:
This. However, I think other manufactures have a similar thing.
Yessir. Each manufacturer has some kind of way to regulate voltage in some sort of way, and there is usually a product on the market to bypass it or work around it. To the best of my knowledge, there are no bypasses on the market for the Hondas out there. So keep_hope_alive on the Accord forums did a lot of research and figured out what needs to be done to bypass the ELD. I went ahead and did the bypass just to confirm that it worked, and I did my own little write-up about it over here because I feel it would be a huge benefit to the Honda drivers in the car audio game.
Very helpful thread! I'd like to see an addition to Acura Integra. Stupid ELD is gaye on mine as well. I need to find where that stupid ELD is located in my teg.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
I will research and make an edit to the first page with the updated Teg wiring homie. Year and what kind of Teg? Engine, trim package, all that minor stuff....
Leave the info here and I'll post it up later when I get home from class tonight.
96 Acura Integra LS. Been suffering with all that AC, Headligh, Defrost, etc being turned on... lol If you can find out, I'd be much appreicated.
Can't seen to keep up with the voltage above 12.8's with just 3k watts at idle. While car is rolling is a different story though. While the car is moving, that 3k barely tickles the volt (14.0 is the lowest). My AB500.1 don't dip below 13.x connect @ 0.5 ohm while the car is rolling.
What kind of electrical do you have now? I'm in class til 11 tonight, but I'll get the wires and location of the ELD for you when I get home
  • Who's Online   0 Members, 0 Anonymous, 314 Guests (See full list)
