Posted (edited)
hmm because i bought a cheap ass kit and it didnt work right and all i did was flip the plug around and shit worked perfect
some cars have reversed polarity for the headlights. doesn't matter how cheap a kit is. if you buy a $10 ballast or a $300 ballast, you'll still have to reverse the plug going into it.
edit: when the plug is in the wrong way, the ballast wont even fire whatsoever.
Edited by Kranny
That has to do with reverse polarity, not quite his issue, at least I dont think. Like Kranny said 35w should be much brighter than regular bulbs, I went with 55w but I dont have projectors. Could be a bad ballast and its not giving the correct power or something could be wrong with the bulb themselves, did you try switching the bulbs and ballasts around and see if it changes? Does one side look brighter than the other?
2002 Ford Explorer XLT
Front Stage: Crescendo CCX 6.5's
Rear Stage: ???
Two 15" Powerbass M154
Audiopipe AP15001d
Pioneer DEH-P5100UB
  • 1 month later...
I didn't switch anything around to check but the right side seems to be a bit better then the left.
how cheap of a Kit did you get?
the "Xentec" brand?..
I had those and they were plain shitty.
I now bought a set of Raptor V2 35w. 4500k . and They are Bright.. they are a little more expensive though..
you get what you pay for
Have you tried hooking up the hid ballasts to the battery? Some factory wiring won't be able to provide enough amperes to fully power it...
2015 Honda Civic LX 4dr | 110k miles | Stock
1996 GMC Yukon SLT 4dr 4wd | 260k miles | JVC Head-unit
